Datasheet Wago 232-211/026-000 — Даташит
1-проводниковая розетка; угловые; 2,5 мм²; Шаг контактов 5 мм; 11-пол.
1-CONDUCTOR FEMALE PLUG; ANGLED; | |||
232-211/026-000 Wago | по запросу |
Цвет | gray |
Conductor entry direction to mating direction | 90 ° |
Contact material | Copper alloy |
Country of origin | PL |
Габариты: глубина | 22.75 mm / 0.896 inch |
Design | angled |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.337 MJ |
GTIN | 4044918388221 |
Height | 19.9 mm / 0.783 inch |
Material group | I |
Mismating protection | No |
Number of Poles | 11 |
Number of levels | 1 |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 14 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 11 |
Total number of potentials | 11 |
Вес | 20.537 г |
Ширина | 57.4 mm / 2.26 inch |
Серия: 232 (100 из 896)
- 232-174/047-000 232-175 232-175/031-000 232-175/039-000 232-175/047-000 232-176 232-176/031-000 232-176/039-000 232-176/047-000 232-177 232-177/031-000 232-177/039-000 232-177/047-000 232-178 232-178/031-000 232-178/039-000 232-178/047-000 232-179 232-179/031-000 232-179/039-000 232-179/047-000 232-180 232-180/031-000 232-180/039-000 232-180/047-000 232-181 232-181/031-000 232-181/039-000 232-181/047-000 232-182 232-182/031-000 232-182/039-000 232-182/047-000 232-183 232-183/031-000 232-183/039-000 232-183/047-000 232-184 232-184/031-000 232-184/039-000 232-184/047-000 232-202/026-000 232-203/026-000 232-204/026-000 232-205/026-000 232-206/026-000 232-207/026-000 232-208/026-000 232-209/026-000 232-210/026-000 232-211/026-000 232-212/026-000 232-213/026-000 232-214/026-000 232-215/026-000 232-216/026-000 232-217/026-000 232-218/026-000 232-219/026-000 232-220/026-000 232-221/026-000 232-222/026-000 232-223/026-000 232-224/026-000 232-232 232-232/005-000 232-232/005-000/039-000 232-232/031-000 232-232/039-000 232-232/047-000 232-233 232-233/005-000 232-233/005-000/039-000 232-233/031-000 232-233/039-000 232-233/047-000 232-234 232-234/005-000 232-234/005-000/039-000 232-234/031-000 232-234/039-000 232-234/047-000 232-235 232-235/005-000 232-235/005-000/039-000 232-235/031-000 232-235/039-000 232-235/047-000 232-236 232-236/005-000 232-236/005-000/039-000 232-236/031-000 232-236/039-000 232-236/047-000 232-237 232-237/005-000 232-237/005-000/039-000 232-237/031-000 232-237/039-000 232-237/047-000
232211/026000, 232 211/026 000
