Datasheet Wago 232-114/026-000 — Даташит
1-проводниковая розетка; угловые; 2,5 мм²; Шаг контактов 5 мм; 14-пол.
1-CONDUCTOR FEMALE PLUG; ANGLED; | |||
232-114/026-000 Wago | по запросу |
Цвет | gray |
Conductor entry direction to mating direction | 270 ° |
Contact material | Copper alloy |
Country of origin | PL |
Габариты: глубина | 22.75 mm / 0.896 inch |
Design | angled |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.425 MJ |
GTIN | 4044918384100 |
Height | 23.9 mm / 0.941 inch |
Material group | I |
Mismating protection | No |
Number of Poles | 14 |
Number of levels | 1 |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 14 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 14 |
Total number of potentials | 14 |
Вес | 26.106 г |
Ширина | 72.4 mm / 2.85 inch |
Серия: 232 (100 из 896)
- 232-102/026-000 232-103/026-000 232-104/026-000 232-105/026-000 232-106/026-000 232-107/026-000 232-108/026-000 232-109/026-000 232-110/026-000 232-111/026-000 232-112/026-000 232-113/026-000 232-114/026-000 232-115/026-000 232-116/026-000 232-117/026-000 232-118/026-000 232-119/026-000 232-120/026-000 232-121/026-000 232-122/026-000 232-123/026-000 232-124/026-000 232-132 232-132/005-000 232-132/005-000/039-000 232-132/031-000 232-132/039-000 232-132/047-000 232-133 232-133/005-000 232-133/005-000/039-000 232-133/031-000 232-133/039-000 232-133/047-000 232-134 232-134/005-000 232-134/005-000/039-000 232-134/031-000 232-134/039-000 232-134/047-000 232-135 232-135/005-000 232-135/005-000/039-000 232-135/031-000 232-135/039-000 232-135/047-000 232-136 232-136/005-000 232-136/005-000/039-000 232-136/031-000 232-136/039-000 232-136/047-000 232-137 232-137/005-000 232-137/005-000/039-000 232-137/031-000 232-137/039-000 232-137/047-000 232-138 232-138/005-000 232-138/005-000/039-000 232-138/031-000 232-138/039-000 232-138/047-000 232-139 232-139/005-000 232-139/005-000/039-000 232-139/031-000 232-139/039-000 232-139/047-000 232-140 232-140/005-000 232-140/005-000/039-000 232-140/031-000 232-140/039-000 232-140/047-000 232-141 232-141/005-000 232-141/005-000/039-000 232-141/031-000 232-141/039-000 232-141/047-000 232-142 232-142/005-000 232-142/005-000/039-000 232-142/031-000 232-142/039-000 232-142/047-000 232-143 232-143/005-000 232-143/005-000/039-000 232-143/031-000 232-143/039-000 232-143/047-000 232-144 232-144/005-000 232-144/005-000/039-000 232-144/031-000 232-144/039-000
232114/026000, 232 114/026 000
