Datasheet Wago 231-2210/026-000 — Даташит
2-проводная розетка; 2,5 мм²; Шаг контактов 7,5 мм; 10-пол.
2-CONDUCTOR FEMALE CONNECTOR; 2. | |||
231-2210/026-000 Wago | по запросу |
Цвет | gray |
Contact material | Copper alloy |
Country of origin | PL |
Габариты: глубина | 26.45 mm / 1.041 inch |
Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
Fire load | 0.519 MJ |
GTIN | 4044918563901 |
Height | 20.8 mm / 0.819 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mismating protection | No |
Number of Poles | 10 |
Number of levels | 1 |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
Total number of connection points | 20 |
Total number of potentials | 10 |
Вес | 27.54 г |
Ширина | 72.5 mm / 2.854 inch |
Серия: 231 (100 из 1349)
- 231-211/008-000 231-211/026-000 231-211/027-000 231-211/031-000 231-211/037-000 231-2110/026-000 231-2110/037-000 231-2111/026-000 231-2111/037-000 231-2112/026-000 231-2112/037-000 231-2113/026-000 231-2113/037-000 231-2114/026-000 231-2114/037-000 231-2115/026-000 231-2115/037-000 231-2116/026-000 231-2116/037-000 231-212/008-000 231-212/026-000 231-212/027-000 231-212/031-000 231-212/037-000 231-213/008-000 231-213/026-000 231-213/027-000 231-213/031-000 231-213/037-000 231-216/008-000 231-216/026-000 231-216/027-000 231-216/031-000 231-216/037-000 231-2202/026-000 231-2202/037-000 231-2203/026-000 231-2203/037-000 231-2204/026-000 231-2204/037-000 231-2205/026-000 231-2205/037-000 231-2206/026-000 231-2206/037-000 231-2207/026-000 231-2207/037-000 231-2208/026-000 231-2208/037-000 231-2209/026-000 231-2209/037-000 231-2210/026-000 231-2210/037-000 231-2211/026-000 231-2211/037-000 231-2212/026-000 231-2212/037-000 231-2302/026-000 231-2302/037-000 231-2302/107-000 231-2303/026-000 231-2303/037-000 231-2303/107-000 231-2304/026-000 231-2304/037-000 231-2304/107-000 231-2305/026-000 231-2305/037-000 231-2305/107-000 231-2306/026-000 231-2306/037-000 231-2306/107-000 231-2307/026-000 231-2307/037-000 231-2307/107-000 231-2308/026-000 231-2308/037-000 231-2308/107-000 231-2309/026-000 231-2309/037-000 231-2309/107-000 231-2310/026-000 231-2310/037-000 231-2310/107-000 231-2311/026-000 231-2311/037-000 231-2312/026-000 231-2312/037-000 231-2312/107-000 231-2313/026-000 231-2313/037-000 231-2314/026-000 231-2314/037-000 231-2314/107-000 231-2315/026-000 231-2315/037-000 231-2315/107-000 231-2316/026-000 231-2316/037-000 231-2316/107-000 231-232/001-000
2312210/026000, 231 2210/026 000
