Datasheet Wago 231-872/001-000 — Даташит
Вилка THT; 1.2 x 1.2 mm solder pin; угловые; Шаг контактов 7,5 мм; 12-пол.
THT MALE HEADER; 1.2 X 1.2 MM SO | |||
231-872/001-000 Wago | по запросу |
Цвет | gray |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 12 mm / 0.472 inch |
Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
Fire load | 0.093 MJ |
GTIN | 4044918932332 |
Height | 12.2 mm / 0.48 inch |
Height from the surface | 8.4 mm / 0.331 inch |
Material group | I |
Mismating protection | No |
Number of Poles | 12 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1.2 x 1.2 mm |
Solder pin length | 3.8 мм |
Total number of potentials | 12 |
Вес | 5.38 г |
Ширина | 90.7 mm / 3.571 inch |
Серия: 231 (100 из 1349)
- 231-766/001-000 231-767/001-000 231-768/001-000 231-769/001-000 231-770/001-000 231-771/001-000 231-772/001-000 231-832/001-000 231-832/001-000/105-604 231-832/001-000/105-604/997-405 231-833/001-000 231-833/001-000/105-604 231-833/001-000/105-604/997-407 231-834/001-000 231-834/001-000/105-604 231-834/001-000/105-604/997-407 231-835/001-000 231-835/001-000/105-604 231-835/001-000/105-604/997-407 231-836/001-000 231-836/001-000/105-604 231-836/001-000/105-604/997-409 231-837/001-000 231-837/001-000/105-604 231-837/001-000/105-604/997-409 231-838/001-000 231-838/001-000/105-604 231-838/001-000/105-604/997-409 231-839/001-000 231-839/001-000/105-604 231-839/001-000/105-604/997-409 231-840/001-000 231-840/001-000/105-604 231-840/040-000 231-841/001-000 231-841/001-000/105-604 231-842/001-000 231-842/001-000/105-604 231-843/001-000 231-846/001-000 231-862/001-000 231-862/001-000/105-604 231-862/001-000/105-604/997-405 231-863/001-000 231-863/001-000/105-604 231-863/001-000/105-604/997-407 231-864/001-000 231-864/001-000/105-604 231-864/001-000/105-604/997-407 231-865/001-000 231-865/001-000/105-604 231-865/001-000/105-604/997-407 231-866/001-000 231-866/001-000/105-604 231-866/001-000/105-604/997-409 231-867/001-000 231-867/001-000/105-604 231-867/001-000/105-604/997-409 231-868/001-000 231-868/001-000/105-604 231-868/001-000/105-604/997-409 231-869/001-000 231-869/001-000/105-604 231-869/001-000/105-604/997-409 231-870/001-000 231-870/001-000/105-604 231-870/040-000 231-871/001-000 231-871/001-000/105-604 231-872/001-000 231-872/001-000/105-604 231-873/001-000 231-876/001-000 231-902 231-903 231-905 231-907 231-910 231-932/001-000 231-933/001-000 231-934/001-000 231-935/001-000 231-936/001-000 231-937/001-000 231-938/001-000 231-939/001-000 231-940/001-000 231-941/001-000 231-942/001-000 231-962/001-000 231-963/001-000 231-964/001-000 231-965/001-000 231-966/001-000 231-967/001-000 231-968/001-000 231-969/001-000 231-970/001-000 231-971/001-000 231-972/001-000
231872/001000, 231 872/001 000
