Datasheet Wago 231-863/001-000/105-604/997-407 — Даташит
Вилка под пайку THR; 1.2 x 1.2 mm solder pin; угловые; упаковка в ленте на бобине; Шаг контактов 7,5 мм; 3-пол.
THR MALE HEADER; 1.2 X 1.2 MM SO | |||
231-863/001-000/105-604/997-407 Wago | по запросу |
Цвет | black |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 12 mm / 0.472 inch |
GTIN | 4050821043232 |
Height | 10.8 mm / 0.425 inch |
Height from the surface | 8.4 mm / 0.331 inch |
Insulating material | Polyphtalamide (PPA GF) |
Material group | I |
Mismating protection | No |
Number of Poles | 3 |
Number of levels | 1 |
PCB contact | THR |
Packaging type | bag |
Pin spacing | 7.5 mm (0.295 inch) |
Plated through-hole diameter (THR) | 1.7 (+ 0.1) мм |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Reel diameter of tape-and-reel packaging | 330 мм |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1.2 x 1.2 mm |
Solder pin length | 2.4 мм |
Tape width | 56 мм |
Total number of potentials | 3 |
Вес | 1.619 г |
Ширина | 23.2 mm / 0.913 inch |
Серия: 231 (100 из 1349)
- 231-742/001-000 231-762/001-000 231-763/001-000 231-764/001-000 231-765/001-000 231-766/001-000 231-767/001-000 231-768/001-000 231-769/001-000 231-770/001-000 231-771/001-000 231-772/001-000 231-832/001-000 231-832/001-000/105-604 231-832/001-000/105-604/997-405 231-833/001-000 231-833/001-000/105-604 231-833/001-000/105-604/997-407 231-834/001-000 231-834/001-000/105-604 231-834/001-000/105-604/997-407 231-835/001-000 231-835/001-000/105-604 231-835/001-000/105-604/997-407 231-836/001-000 231-836/001-000/105-604 231-836/001-000/105-604/997-409 231-837/001-000 231-837/001-000/105-604 231-837/001-000/105-604/997-409 231-838/001-000 231-838/001-000/105-604 231-838/001-000/105-604/997-409 231-839/001-000 231-839/001-000/105-604 231-839/001-000/105-604/997-409 231-840/001-000 231-840/001-000/105-604 231-840/040-000 231-841/001-000 231-841/001-000/105-604 231-842/001-000 231-842/001-000/105-604 231-843/001-000 231-846/001-000 231-862/001-000 231-862/001-000/105-604 231-862/001-000/105-604/997-405 231-863/001-000 231-863/001-000/105-604 231-863/001-000/105-604/997-407 231-864/001-000 231-864/001-000/105-604 231-864/001-000/105-604/997-407 231-865/001-000 231-865/001-000/105-604 231-865/001-000/105-604/997-407 231-866/001-000 231-866/001-000/105-604 231-866/001-000/105-604/997-409 231-867/001-000 231-867/001-000/105-604 231-867/001-000/105-604/997-409 231-868/001-000 231-868/001-000/105-604 231-868/001-000/105-604/997-409 231-869/001-000 231-869/001-000/105-604 231-869/001-000/105-604/997-409 231-870/001-000 231-870/001-000/105-604 231-870/040-000 231-871/001-000 231-871/001-000/105-604 231-872/001-000 231-872/001-000/105-604 231-873/001-000 231-876/001-000 231-902 231-903 231-905 231-907 231-910 231-932/001-000 231-933/001-000 231-934/001-000 231-935/001-000 231-936/001-000 231-937/001-000 231-938/001-000 231-939/001-000 231-940/001-000 231-941/001-000 231-942/001-000 231-962/001-000 231-963/001-000 231-964/001-000 231-965/001-000 231-966/001-000 231-967/001-000
231863/001000/105604/997407, 231 863/001 000/105 604/997 407
