Datasheet Wago 231-735/001-000 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; прямые; Шаг контактов 7,62 мм; 5-пол.
Цвет | orange |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 8.4 mm / 0.331 inch |
Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
Fire load | 0.042 MJ |
GTIN | 4044918867818 |
Height | 17 mm / 0.669 inch |
Height from the surface | 12 mm / 0.472 inch |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | No |
Number of Poles | 5 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 7.62 mm (0.3 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1 x 1 mm |
Solder pin length | 5 мм |
Total number of potentials | 5 |
Вес | 2.05 г |
Ширина | 38.68 mm / 1.523 inch |
Серия: 231 (100 из 1349)
- 231-703/008-000 231-703/026-000 231-703/031-000 231-703/037-000 231-704/008-000 231-704/026-000 231-704/031-000 231-704/037-000 231-705/008-000 231-705/026-000 231-705/031-000 231-705/037-000 231-706/008-000 231-706/026-000 231-706/027-000 231-706/031-000 231-706/037-000 231-707/008-000 231-707/026-000 231-707/027-000 231-707/031-000 231-707/037-000 231-708/008-000 231-708/026-000 231-708/027-000 231-708/031-000 231-708/037-000 231-709/008-000 231-709/026-000 231-709/027-000 231-709/031-000 231-709/037-000 231-710/008-000 231-710/026-000 231-710/027-000 231-710/031-000 231-710/037-000 231-711/008-000 231-711/026-000 231-711/027-000 231-711/031-000 231-711/037-000 231-712/008-000 231-712/026-000 231-712/027-000 231-712/031-000 231-712/037-000 231-732/001-000 231-733/001-000 231-734/001-000 231-735/001-000 231-736/001-000 231-737/001-000 231-738/001-000 231-739/001-000 231-740/001-000 231-741/001-000 231-742/001-000 231-762/001-000 231-763/001-000 231-764/001-000 231-765/001-000 231-766/001-000 231-767/001-000 231-768/001-000 231-769/001-000 231-770/001-000 231-771/001-000 231-772/001-000 231-832/001-000 231-832/001-000/105-604 231-832/001-000/105-604/997-405 231-833/001-000 231-833/001-000/105-604 231-833/001-000/105-604/997-407 231-834/001-000 231-834/001-000/105-604 231-834/001-000/105-604/997-407 231-835/001-000 231-835/001-000/105-604 231-835/001-000/105-604/997-407 231-836/001-000 231-836/001-000/105-604 231-836/001-000/105-604/997-409 231-837/001-000 231-837/001-000/105-604 231-837/001-000/105-604/997-409 231-838/001-000 231-838/001-000/105-604 231-838/001-000/105-604/997-409 231-839/001-000 231-839/001-000/105-604 231-839/001-000/105-604/997-409 231-840/001-000 231-840/001-000/105-604 231-840/040-000 231-841/001-000 231-841/001-000/105-604 231-842/001-000 231-842/001-000/105-604
231735/001000, 231 735/001 000
