Datasheet Wago 231-710/026-000 — Даташит
1-проводниковая розетка; 2,5 мм²; Шаг контактов 7,62 мм; 10-пол.
1-CONDUCTOR FEMALE PLUG; 2.5 MM; | |||
231-710/026-000 Wago | по запросу |
Цвет | orange |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 26.45 mm / 1.041 inch |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.346 MJ |
GTIN | 4044918352444 |
Height | 14.3 mm / 0.563 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mismating protection | No |
Number of Poles | 10 |
Number of levels | 1 |
Pin spacing | 7.62 mm (0.3 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 10 |
Total number of potentials | 10 |
Вес | 21.02 г |
Ширина | 75.16 mm / 2.959 inch |
Серия: 231 (100 из 1349)
- 231-653/114-000 231-654 231-654/018-000 231-654/018-000/035-000 231-654/019-000 231-654/114-000 231-661 231-662 231-668 231-669 231-670 231-671 231-672 231-702/008-000 231-702/026-000 231-702/031-000 231-702/037-000 231-703/008-000 231-703/026-000 231-703/031-000 231-703/037-000 231-704/008-000 231-704/026-000 231-704/031-000 231-704/037-000 231-705/008-000 231-705/026-000 231-705/031-000 231-705/037-000 231-706/008-000 231-706/026-000 231-706/027-000 231-706/031-000 231-706/037-000 231-707/008-000 231-707/026-000 231-707/027-000 231-707/031-000 231-707/037-000 231-708/008-000 231-708/026-000 231-708/027-000 231-708/031-000 231-708/037-000 231-709/008-000 231-709/026-000 231-709/027-000 231-709/031-000 231-709/037-000 231-710/008-000 231-710/026-000 231-710/027-000 231-710/031-000 231-710/037-000 231-711/008-000 231-711/026-000 231-711/027-000 231-711/031-000 231-711/037-000 231-712/008-000 231-712/026-000 231-712/027-000 231-712/031-000 231-712/037-000 231-732/001-000 231-733/001-000 231-734/001-000 231-735/001-000 231-736/001-000 231-737/001-000 231-738/001-000 231-739/001-000 231-740/001-000 231-741/001-000 231-742/001-000 231-762/001-000 231-763/001-000 231-764/001-000 231-765/001-000 231-766/001-000 231-767/001-000 231-768/001-000 231-769/001-000 231-770/001-000 231-771/001-000 231-772/001-000 231-832/001-000 231-832/001-000/105-604 231-832/001-000/105-604/997-405 231-833/001-000 231-833/001-000/105-604 231-833/001-000/105-604/997-407 231-834/001-000 231-834/001-000/105-604 231-834/001-000/105-604/997-407 231-835/001-000 231-835/001-000/105-604 231-835/001-000/105-604/997-407 231-836/001-000 231-836/001-000/105-604
231710/026000, 231 710/026 000
