Datasheet Wago 231-703/031-000 — Даташит
1-проводниковая розетка; зажимное кольцо; 2,5 мм²; Шаг контактов 7,62 мм; 3-пол.
1-CONDUCTOR FEMALE PLUG; CLAMPIN | |||
231-703/031-000 Wago | по запросу |
Цвет | orange |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 26.45 mm / 1.041 inch |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.124 MJ |
GTIN | 4044918376464 |
Height | 14.3 mm / 0.563 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mismating protection | No |
Mounting type | Mounting flange |
Number of Poles | 3 |
Number of levels | 1 |
Pin spacing | 7.62 mm (0.3 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 3 |
Total number of potentials | 3 |
Type of mounting | Feed-through mounting Panel mounting |
Вес | 6.981 г |
Ширина | 35.12 mm / 1.383 inch |
Серия: 231 (100 из 1349)
- 231-646/019-000 231-646/109-000 231-646/114-000 231-646/129-000 231-647 231-647/018-000 231-647/019-000 231-647/114-000 231-648 231-648/018-000 231-648/019-000 231-648/114-000 231-649 231-649/018-000 231-649/019-000 231-649/114-000 231-650 231-650/018-000 231-650/019-000 231-650/114-000 231-651 231-651/018-000 231-651/019-000 231-651/114-000 231-652 231-652/018-000 231-652/019-000 231-652/114-000 231-653 231-653/018-000 231-653/019-000 231-653/114-000 231-654 231-654/018-000 231-654/018-000/035-000 231-654/019-000 231-654/114-000 231-661 231-662 231-668 231-669 231-670 231-671 231-672 231-702/008-000 231-702/026-000 231-702/031-000 231-702/037-000 231-703/008-000 231-703/026-000 231-703/031-000 231-703/037-000 231-704/008-000 231-704/026-000 231-704/031-000 231-704/037-000 231-705/008-000 231-705/026-000 231-705/031-000 231-705/037-000 231-706/008-000 231-706/026-000 231-706/027-000 231-706/031-000 231-706/037-000 231-707/008-000 231-707/026-000 231-707/027-000 231-707/031-000 231-707/037-000 231-708/008-000 231-708/026-000 231-708/027-000 231-708/031-000 231-708/037-000 231-709/008-000 231-709/026-000 231-709/027-000 231-709/031-000 231-709/037-000 231-710/008-000 231-710/026-000 231-710/027-000 231-710/031-000 231-710/037-000 231-711/008-000 231-711/026-000 231-711/027-000 231-711/031-000 231-711/037-000 231-712/008-000 231-712/026-000 231-712/027-000 231-712/031-000 231-712/037-000 231-732/001-000 231-733/001-000 231-734/001-000 231-735/001-000 231-736/001-000
231703/031000, 231 703/031 000
