Datasheet Wago 231-639/019-000 — Даташит
1-проводная вилка; зажимное кольцо; 2,5 мм²; Шаг контактов 5,08 мм; 9-пол.
1-CONDUCTOR MALE CONNECTOR; CLAM | |||
231-639/019-000 Wago | по запросу | ||
231-639/019000 Littelfuse | по запросу | ||
231-639/019-000 Littelfuse | по запросу |
Цвет | orange |
Country of origin | DE |
Габариты: глубина | 27.5 mm / 1.083 inch |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.255 MJ |
GTIN | 4044918260497 |
Height | 14.3 mm / 0.563 inch |
Material group | I |
Mismating protection | No |
Mounting type | Mounting flange |
Number of Poles | 9 |
Number of levels | 1 |
Pin spacing | 5.08 mm (0.2 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 9 |
Total number of potentials | 9 |
Type of mounting | Feed-through mounting Panel mounting |
Вес | 14.87 г |
Ширина | 60.52 mm / 2.383 inch |
Серия: 231 (100 из 1349)
- 231-633/018-000 231-633/019-000 231-633/023-000 231-633/109-000 231-633/114-000 231-633/129-000 231-634 231-634/017-000 231-634/018-000 231-634/019-000 231-634/023-000 231-634/109-000 231-634/114-000 231-634/129-000 231-635 231-635/017-000 231-635/018-000 231-635/019-000 231-635/023-000 231-635/109-000 231-635/114-000 231-635/129-000 231-636 231-636/017-000 231-636/018-000 231-636/019-000 231-636/023-000 231-636/109-000 231-636/114-000 231-636/129-000 231-637 231-637/017-000 231-637/018-000 231-637/019-000 231-637/019-000/034-000 231-637/023-000 231-637/109-000 231-637/114-000 231-637/129-000 231-638 231-638/017-000 231-638/018-000 231-638/019-000 231-638/023-000 231-638/109-000 231-638/114-000 231-638/129-000 231-639 231-639/017-000 231-639/018-000 231-639/019-000 231-639/023-000 231-639/109-000 231-639/114-000 231-639/129-000 231-640 231-640/017-000 231-640/018-000 231-640/019-000 231-640/023-000 231-640/109-000 231-640/114-000 231-640/129-000 231-641 231-641/017-000 231-641/018-000 231-641/019-000 231-641/023-000 231-641/114-000 231-642 231-642/017-000 231-642/018-000 231-642/019-000 231-642/023-000 231-642/109-000 231-642/114-000 231-642/129-000 231-643 231-643/018-000 231-643/019-000 231-643/114-000 231-644 231-644/018-000 231-644/019-000 231-644/109-000 231-644/114-000 231-644/129-000 231-645 231-645/018-000 231-645/019-000 231-645/109-000 231-645/114-000 231-645/129-000 231-646 231-646/018-000 231-646/019-000 231-646/109-000 231-646/114-000 231-646/129-000 231-647
231639/019000, 231 639/019 000
