Datasheet Wago 231-575/108-000 — Даташит
Вилка THT; 1.2 x 1.2 mm solder pin; угловые; Резьбовой фланец; Шаг контактов 5,08 мм; 15-пол.
THT MALE HEADER; 1.2 X 1.2 MM SO | |||
231-575/108-000 Wago | по запросу |
Цвет | orange |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 12 mm / 0.472 inch |
Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
Fire load | 0.099 MJ |
GTIN | 4045454845506 |
Height | 12.2 mm / 0.48 inch |
Height from the surface | 8.4 mm / 0.331 inch |
Locking of plug-in connection | Threaded flange |
Material group | I |
Mismating protection | No |
Number of Poles | 15 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5.08 mm (0.2 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1.2 x 1.2 mm |
Solder pin length | 3.8 мм |
Total number of potentials | 15 |
Вес | 6.52 г |
Ширина | 86.2 mm / 3.394 inch |
Серия: 231 (100 из 1349)
- 231-537/108-000 231-538/001-000 231-538/108-000 231-539/001-000 231-539/108-000 231-540/001-000 231-540/108-000 231-541/001-000 231-542/001-000 231-542/108-000 231-543/001-000 231-544/001-000 231-544/108-000 231-545/001-000 231-545/108-000 231-546/001-000 231-546/108-000 231-547/001-000 231-548/001-000 231-549/001-000 231-550/001-000 231-551/001-000 231-552/001-000 231-553/001-000 231-554/001-000 231-562/001-000 231-562/108-000 231-563/001-000 231-563/108-000 231-564/001-000 231-564/108-000 231-565/001-000 231-565/108-000 231-566/001-000 231-566/108-000 231-567/001-000 231-567/108-000 231-568/001-000 231-568/108-000 231-569/001-000 231-569/108-000 231-570/001-000 231-570/108-000 231-571/001-000 231-572/001-000 231-572/108-000 231-573/001-000 231-574/001-000 231-574/108-000 231-575/001-000 231-575/108-000 231-576/001-000 231-576/108-000 231-577/001-000 231-578/001-000 231-579/001-000 231-580/001-000 231-581/001-000 231-582/001-000 231-583/001-000 231-584/001-000 231-602 231-602/017-000 231-602/018-000 231-602/019-000 231-602/023-000 231-602/114-000 231-603 231-603/017-000 231-603/018-000 231-603/019-000 231-603/023-000 231-603/032-000 231-603/114-000 231-604 231-604/017-000 231-604/018-000 231-604/019-000 231-604/023-000 231-604/114-000 231-605 231-605/017-000 231-605/018-000 231-605/019-000 231-605/023-000 231-605/114-000 231-606 231-606/017-000 231-606/018-000 231-606/019-000 231-606/023-000 231-606/114-000 231-607 231-607/017-000 231-607/018-000 231-607/019-000 231-607/019-000/034-000 231-607/023-000 231-607/114-000 231-608
231575/108000, 231 575/108 000
