Datasheet Wago 231-469/001-000 — Даташит
Вилка THT; 1.2 x 1.2 mm solder pin; угловые; Шаг контактов 5 мм; 9-пол.
THT MALE HEADER; 1.2 X 1.2 MM SO | |||
231-469/001-000 Wago | 336 ₽ | ||
231-469/001-000 Wago | по запросу |
Цвет | gray |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 12 mm / 0.472 inch |
Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
Fire load | 0.051 MJ |
GTIN | 4044918930543 |
Height | 12.2 mm / 0.48 inch |
Height from the surface | 8.4 mm / 0.331 inch |
Material group | I |
Mismating protection | No |
Number of Poles | 9 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1.2 x 1.2 mm |
Solder pin length | 3.8 мм |
Total number of potentials | 9 |
Вес | 3.41 г |
Ширина | 48.2 mm / 1.898 inch |
Серия: 231 (100 из 1349)
- 231-439/001-000/105-604 231-439/001-000/105-604/997-409 231-440/001-000 231-440/001-000/105-604 231-440/001-000/105-604/997-409 231-441/001-000 231-441/001-000/105-604 231-441/001-000/105-604/997-409 231-442/001-000 231-442/001-000/105-604 231-442/001-000/105-604/997-409 231-443/001-000 231-444/001-000 231-444/040-000 231-445/001-000 231-446/001-000 231-447/001-000 231-448/001-000 231-449/001-000 231-450/001-000 231-451/001-000 231-452/001-000 231-453/001-000 231-454/001-000 231-455 231-462/001-000 231-462/001-000/105-604 231-462/001-000/105-604/997-405 231-462/040-000 231-463/001-000 231-463/001-000/105-604 231-463/001-000/105-604/997-405 231-463/040-000 231-464/001-000 231-464/001-000/105-604 231-464/001-000/105-604/997-407 231-465/001-000 231-465/001-000/105-604 231-465/001-000/105-604/997-407 231-465/040-000 231-466/001-000 231-466/001-000/105-604 231-466/001-000/105-604/997-407 231-466/040-000 231-467/001-000 231-467/001-000/105-604 231-467/001-000/105-604/997-407 231-468/001-000 231-468/001-000/105-604 231-468/001-000/105-604/997-407 231-469/001-000 231-469/001-000/105-604 231-469/001-000/105-604/997-409 231-470/001-000 231-470/001-000/105-604 231-470/001-000/105-604/997-409 231-471/001-000 231-471/001-000/105-604 231-471/001-000/105-604/997-409 231-472/001-000 231-472/001-000/105-604 231-472/001-000/105-604/997-409 231-473/001-000 231-474/001-000 231-474/040-000 231-475/001-000 231-476/001-000 231-477/001-000 231-478/001-000 231-479/001-000 231-480/001-000 231-481/001-000 231-482/001-000 231-483/001-000 231-484/001-000 231-500 231-532/001-000 231-532/001-000/105-604 231-532/001-000/105-604/997-405 231-532/108-000 231-533/001-000 231-533/001-000/105-604 231-533/001-000/105-604/997-405 231-533/108-000 231-534/001-000 231-534/108-000 231-535/001-000 231-535/108-000 231-536/001-000 231-536/108-000 231-537/001-000 231-537/108-000 231-538/001-000 231-538/108-000 231-539/001-000 231-539/108-000 231-540/001-000 231-540/108-000 231-541/001-000 231-542/001-000
231469/001000, 231 469/001 000
