Datasheet Wago 231-264/001-000/105-604/997-407 — Даташит
Вилка под пайку THR; 1.2 x 1.2 mm solder pin; прямые; упаковка в ленте на бобине; Шаг контактов 7,5 мм; 4-пол.
THR MALE HEADER; 1.2 X 1.2 MM SO | |||
231-264/001-000/105-604/997-407 Wago | по запросу |
Цвет | black |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 8.4 mm / 0.331 inch |
Fire load | 0.047 MJ |
GTIN | 4050821004158 |
Height | 14.4 mm / 0.567 inch |
Height from the surface | 12 mm / 0.472 inch |
Insulating material | Polyphtalamide (PPA GF) |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | No |
Number of Poles | 4 |
Number of levels | 1 |
PCB contact | THR |
Packaging type | bag |
Pin spacing | 7.5 mm (0.295 inch) |
Plated through-hole diameter (THR) | 1.7 (+ 0.1) мм |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Reel diameter of tape-and-reel packaging | 330 мм |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1.2 x 1.2 mm |
Solder pin length | 2.4 мм |
Tape width | 56 мм |
Total number of potentials | 4 |
Вес | 1.736 г |
Ширина | 30.7 mm / 1.209 inch |
Серия: 231 (100 из 1349)
- 231-2314/026-000 231-2314/037-000 231-2314/107-000 231-2315/026-000 231-2315/037-000 231-2315/107-000 231-2316/026-000 231-2316/037-000 231-2316/107-000 231-232/001-000 231-232/001-000/105-604 231-232/001-000/105-604/997-405 231-233/001-000 231-233/001-000/105-604 231-233/001-000/105-604/997-407 231-234/001-000 231-234/001-000/105-604 231-234/001-000/105-604/997-407 231-235/001-000 231-235/001-000/105-604 231-235/001-000/105-604/997-407 231-236/001-000 231-236/001-000/105-604 231-236/001-000/105-604/997-409 231-237/001-000 231-237/001-000/105-604 231-237/001-000/105-604/997-409 231-238/001-000 231-238/001-000/105-604 231-238/001-000/105-604/997-409 231-239/001-000 231-239/001-000/105-604 231-239/001-000/105-604/997-409 231-240/001-000 231-240/001-000/105-604 231-240/040-000 231-241/001-000 231-241/001-000/105-604 231-242/001-000 231-242/001-000/105-604 231-243/001-000 231-246/001-000 231-262/001-000 231-262/001-000/105-604 231-262/001-000/105-604/997-405 231-263/001-000 231-263/001-000/105-604 231-263/001-000/105-604/997-407 231-264/001-000 231-264/001-000/105-604 231-264/001-000/105-604/997-407 231-265/001-000 231-265/001-000/105-604 231-265/001-000/105-604/997-407 231-266/001-000 231-266/001-000/105-604 231-266/001-000/105-604/997-409 231-267/001-000 231-267/001-000/105-604 231-267/001-000/105-604/997-409 231-268/001-000 231-268/001-000/105-604 231-268/001-000/105-604/997-409 231-269/001-000 231-269/001-000/105-604 231-269/001-000/105-604/997-409 231-270/001-000 231-270/001-000/105-604 231-270/040-000 231-270/046-000 231-2702/026-000 231-2702/037-000 231-2703/026-000 231-2703/037-000 231-2704/026-000 231-2704/037-000 231-2705/026-000 231-2705/037-000 231-2706/026-000 231-2706/037-000 231-2707/026-000 231-2707/037-000 231-2708/026-000 231-2708/037-000 231-2709/026-000 231-2709/037-000 231-271/001-000 231-271/001-000/105-604 231-2710/026-000 231-2710/037-000 231-2711/026-000 231-2711/037-000 231-2712/026-000 231-2712/037-000 231-272/001-000 231-272/001-000/105-604 231-273/001-000 231-276/001-000 231-300 231-302/008-000
231264/001000/105604/997407, 231 264/001 000/105 604/997 407
