Datasheet Wago 231-240/040-000 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; прямые; зажимное кольцо; Шаг контактов 7,5 мм; 10-пол.
THT MALE HEADER; 1.0 X 1.0 MM SO | |||
231-240/040-000 Wago | по запросу |
Цвет | gray |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 8.4 mm / 0.331 inch |
Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
Fire load | 0.087 MJ |
GTIN | 4044918864947 |
Height | 17 mm / 0.669 inch |
Height from the surface | 12 mm / 0.472 inch |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | No |
Mounting type | Mounting flange |
Number of Poles | 10 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1 x 1 mm |
Solder pin length | 5 мм |
Total number of potentials | 10 |
Type of mounting | Feed-through mounting Panel mounting |
Вес | 4.192 г |
Ширина | 75.7 mm / 2.98 inch |
Серия: 231 (100 из 1349)
- 231-2308/037-000 231-2308/107-000 231-2309/026-000 231-2309/037-000 231-2309/107-000 231-2310/026-000 231-2310/037-000 231-2310/107-000 231-2311/026-000 231-2311/037-000 231-2312/026-000 231-2312/037-000 231-2312/107-000 231-2313/026-000 231-2313/037-000 231-2314/026-000 231-2314/037-000 231-2314/107-000 231-2315/026-000 231-2315/037-000 231-2315/107-000 231-2316/026-000 231-2316/037-000 231-2316/107-000 231-232/001-000 231-232/001-000/105-604 231-232/001-000/105-604/997-405 231-233/001-000 231-233/001-000/105-604 231-233/001-000/105-604/997-407 231-234/001-000 231-234/001-000/105-604 231-234/001-000/105-604/997-407 231-235/001-000 231-235/001-000/105-604 231-235/001-000/105-604/997-407 231-236/001-000 231-236/001-000/105-604 231-236/001-000/105-604/997-409 231-237/001-000 231-237/001-000/105-604 231-237/001-000/105-604/997-409 231-238/001-000 231-238/001-000/105-604 231-238/001-000/105-604/997-409 231-239/001-000 231-239/001-000/105-604 231-239/001-000/105-604/997-409 231-240/001-000 231-240/001-000/105-604 231-240/040-000 231-241/001-000 231-241/001-000/105-604 231-242/001-000 231-242/001-000/105-604 231-243/001-000 231-246/001-000 231-262/001-000 231-262/001-000/105-604 231-262/001-000/105-604/997-405 231-263/001-000 231-263/001-000/105-604 231-263/001-000/105-604/997-407 231-264/001-000 231-264/001-000/105-604 231-264/001-000/105-604/997-407 231-265/001-000 231-265/001-000/105-604 231-265/001-000/105-604/997-407 231-266/001-000 231-266/001-000/105-604 231-266/001-000/105-604/997-409 231-267/001-000 231-267/001-000/105-604 231-267/001-000/105-604/997-409 231-268/001-000 231-268/001-000/105-604 231-268/001-000/105-604/997-409 231-269/001-000 231-269/001-000/105-604 231-269/001-000/105-604/997-409 231-270/001-000 231-270/001-000/105-604 231-270/040-000 231-270/046-000 231-2702/026-000 231-2702/037-000 231-2703/026-000 231-2703/037-000 231-2704/026-000 231-2704/037-000 231-2705/026-000 231-2705/037-000 231-2706/026-000 231-2706/037-000 231-2707/026-000 231-2707/037-000 231-2708/026-000 231-2708/037-000 231-2709/026-000
231240/040000, 231 240/040 000
