Datasheet Wago 226-111 — Даташит
Серия226
Модель226-111
Клеммная колодка для сквозного монтажа; модульная; быстроразъемное соединение/контакт под пайку 2,8 x 0,8 мм; 1-полюсная; для пластин толщиной 2,5 мм; серая
Кабели и Провод, 2.54mm Pitch Round Conductor Flat Cable - 22AWG (7 x 30) Stranded, Tinned, 11Circuits, Reel 30.48m Length
Molex
12 037 ₽
Molex
12 037 ₽
82-22-6111
Actuation typeOperating tool
Цветgray
Connection technology 2Solder contact
Connection technology 3Quick connect contact
Contact platingtin-plated
Country of originDE
Габариты: глубина26 mm / 1.024 inch
Fine-stranded conductor0.08 … 4 mm² / 28 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 2.5 mm²
Fire load0.054 MJ
GTIN4044918794428
Gehäuseblechstärke2.5 … 2.5 mm / 0.098 … 0.098 inch
Height38.5 mm / 1.516 inch
Height from the surface22 mm / 0.866 inch
Material groupI
Mounting typeSnap-in mounting foot
Number of Poles1
Number of connection points1
Number of connection points (connection type)1
Number of connection types2
Number of levels1
Packaging typebag
Pin spacing6 mm (0.236 inch)
Rated current20 A
Rated current (2)6 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)320 В
Ratings noteSolder contact
Ratings note 2Quick connect contact
Solid conductor0.08 … 4 mm² / 28 … 12 AWG
Strip length9 … 10 mm / 0.35 … 0.39 Inch
Total number of connection points1
Total number of potentials1
Type of mountingFeed-through mounting
Вес3.426 г
Ширина6 mm / 0.236 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 226-111
