Datasheet Wago 218-104/000-604 — Даташит
Клеммная колодка THR PCB; Фиксирующие задвижки; 0,5 мм²; Шаг контактов 2,5 мм; 4-полюсный; CAGE CLAMP
THR PCB TERMINAL BLOCK; LOCKING | |||
218-104/000-604 Wago | по запросу |
Actuation type | Confirmation slide switch |
Цвет | black |
Conductor entry angle to the PCB | 40 ° |
Country of origin | PL |
Габариты: глубина | 13 mm / 0.512 inch |
Fine-stranded conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 mm² |
Fire load | 0.019 MJ |
Flammability class per UL94 | V2 |
GTIN | 4045454471897 |
Height | 10.9 mm / 0.429 inch |
Height from the surface | 8.1 mm / 0.319 inch |
Insulating material | Polyamide 46 (PA 46) |
Limit temperature range | -60 … +115 °C |
Material group | III a |
Number of Poles | 4 |
Number of levels | 1 |
PCB contact | THR |
Pin spacing | 2.5 mm (0.098 inch) |
Plated through-hole diameter (THR) | 1.1 (+ 0.1) мм |
Rated current | 6 A |
Rated voltage (III / 3) | 32 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.5 x 0.75 mm |
Solder pin length | 2.8 мм |
Solid conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
Total number of connection points | 4 |
Total number of potentials | 4 |
Вес | 1.368 г |
Ширина | 11.5 mm / 0.453 inch |
Серия: 218 (100 из 119)
- 218-102 218-102/000-604 218-102/000-604/997-403 218-103 218-103/000-604 218-103/000-604/997-405 218-104 218-104/000-005 218-104/000-012 218-104/000-604 218-104/000-604/997-405 218-105 218-105/000-012 218-105/000-604 218-105/000-604/997-405 218-106 218-106/000-005 218-106/000-006 218-106/000-012 218-106/000-023 218-106/000-604 218-106/000-604/997-405 218-107 218-107/000-012 218-107/000-604 218-107/000-604/997-405 218-108 218-108/000-006 218-108/000-012 218-108/000-023 218-109 218-109/000-012 218-110 218-110/000-012 218-111 218-111/000-012 218-112 218-112/000-012 218-113 218-113/000-012 218-114 218-114/000-012 218-115 218-115/000-012 218-116 218-116/000-012 218-117 218-117/000-012 218-118 218-118/000-012 218-119 218-119/000-012 218-120 218-120/000-012 218-121 218-121/000-012 218-122 218-122/000-012 218-123 218-123/000-012 218-124 218-502 218-502/000-006 218-502/000-012 218-502/000-604 218-502/000-604/997-403 218-503 218-503/000-012 218-503/000-604 218-503/000-604/997-405 218-504 218-504/000-012 218-504/000-604 218-504/000-604/997-405 218-505 218-505/000-006 218-505/000-604 218-505/000-604/997-405 218-506 218-506/000-012 218-506/000-604 218-506/000-604/997-405 218-507 218-507/000-012 218-507/000-604 218-507/000-604/997-405 218-508 218-508/000-012 218-509 218-509/000-012 218-510 218-510/000-012 218-511 218-511/000-012 218-512 218-512/000-005 218-512/000-012 218-513 218-513/000-012 218-514
- PCB Interconnect
218104/000604, 218 104/000 604
