Datasheet Wago 2022-106/000-039/999-953 — Даташит
Серия2022
Модель2022-106/000-039/999-953
1-проводниковая розетка; 2,5 мм²; 6-пол.
Actuation typeOperating tool Push-in
Цветgreen-yellow, blue, gray
Country of originDE
Габариты: глубина22.4 mm / 0.882 inch
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
GTIN4055143534116
Height40.5 mm / 1.594 inch
Marking levelSide marking
Nominal cross section2.5 mm²
Number of Poles6
Rated voltage EN (Ex e II)630 В
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points6
Total number of potentials6
Вес19.727 г
Ширина31.2 mm / 1.228 inch
Серия: 2022 (100 из 251)
  • Rail / Chassis Terminal blocks | Pluggable Connection Systems
2022106/000039/999953, 2022 106/000 039/999 953
На английском языке: Datasheet Wago 2022-106/000-039/999-953
