Datasheet Wago 2022-114/000-037 — Даташит
1-проводниковая розетка; 2,5 мм²; 14-пол.
1-CONDUCTOR FEMALE PLUG; 2.5 MM; | |||
2022-114/000-037 Wago | по запросу |
Actuation type | Operating tool Push-in |
Цвет | green-yellow, gray |
Connectable conductor materials | Copper |
Country of origin | DE |
Габариты: глубина | 22.4 mm / 0.882 inch |
Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
Fire load | 0.749 MJ |
GTIN | 4045454913090 |
Height | 40.5 mm / 1.594 inch |
Marking level | Side marking |
Nominal cross section | 2.5 mm² |
Number of Poles | 14 |
Product Group | 18 (X-COM-System) |
Rated current | 24 A |
Rated current (2) | 32 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 690 В |
Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
Total number of connection points | 14 |
Total number of potentials | 14 |
Type of wiring | Front-entry wiring |
Вес | 46.22 г |
Ширина | 72.8 mm / 2.866 inch |
Серия: 2022 (100 из 251)
- 2022-109/000-016 2022-109/000-036 2022-109/000-037 2022-109/000-038 2022-109/000-039 2022-109/123-000 2022-109/135-000 2022-109/145-000 2022-110 2022-110/000-006 2022-110/000-012 2022-110/000-016 2022-110/000-037 2022-110/000-039 2022-110/123-000 2022-110/135-000 2022-110/145-000 2022-111 2022-111/000-006 2022-111/000-012 2022-111/000-016 2022-111/000-037 2022-111/000-039 2022-111/126-000 2022-111/136-000 2022-111/146-000 2022-112 2022-112/000-006 2022-112/000-012 2022-112/000-016 2022-112/000-036 2022-112/000-037 2022-112/000-038 2022-112/000-039 2022-112/126-000 2022-112/136-000 2022-112/146-000 2022-113 2022-113/000-006 2022-113/000-012 2022-113/000-016 2022-113/000-037 2022-113/000-039 2022-113/126-000 2022-113/136-000 2022-113/146-000 2022-114 2022-114/000-006 2022-114/000-012 2022-114/000-016 2022-114/000-037 2022-114/000-039 2022-114/126-000 2022-114/136-000 2022-114/146-000 2022-115 2022-115/000-006 2022-115/000-012 2022-115/000-016 2022-115/000-037 2022-115/000-039 2022-115/127-000 2022-115/137-000 2022-115/147-000 2022-1201 2022-1201/999-953 2022-1202 2022-1204 2022-1204/999-953 2022-1207 2022-1207/999-953 2022-1291 2022-1292 2022-1301 2022-1301/999-953 2022-1302 2022-1304 2022-1304/999-953 2022-1307 2022-1307/999-953 2022-1391 2022-1392 2022-1401 2022-1401/999-953 2022-1402 2022-1404 2022-1404/999-953 2022-1407 2022-1407/999-953 2022-141 2022-142 2022-1491 2022-1492 2022-151 2022-152 2022-161 2022-162 2022-164 2022-167 2022-171
- Rail / Chassis Terminal blocks | Pluggable Connection Systems
2022114/000037, 2022 114/000 037
