Datasheet Wago 2004-555 — Даташит
Соединительная планка TOPJOB S; для гнезда для перемычек; 5-полюсная
MODULAR TOPJOBS CONNECTOR; MODUL | |||
2004-555 Wago | по запросу |
Цвет | gray |
Country of origin | DE |
Fine-stranded conductor | 0.5 … 6 mm² / 20 … 10 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 1.5 mm² / 18 AWG |
Fire load | 0.355 MJ |
GTIN | 4045454178451 |
Marking level | Center/side marking |
Nominal cross section | 4 mm² |
Number of Poles | 5 |
Product Group | 22 (TOPJOB S) |
Rated current | 32 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 500 В |
Solid conductor | 0.5 … 6 mm² / 20 … 10 AWG |
Solid conductor, push-in termination | 1.5 … 6 mm² / 14 … 10 AWG |
Strip length | 11 … 13 mm / 0.43 … 0.51 Inch |
Total number of connection points | 5 |
Total number of potentials | 5 |
Type of wiring | Side-entry wiring |
Вес | 22.475 г |
Ширина | 31 mm / 1.22 inch |
Серия: 2004 (74)
- 2004-115 2004-1201 2004-1202 2004-1203 2004-1204 2004-1205 2004-1206 2004-1207 2004-1211/1000-400 2004-1211/1000-401 2004-1291 2004-1292 2004-1293 2004-1294 2004-1301 2004-1302 2004-1303 2004-1304 2004-1305 2004-1306 2004-1307 2004-1311/1000-400 2004-1311/1000-401 2004-1391 2004-1392 2004-1393 2004-1394 2004-1401 2004-1402 2004-1403 2004-1404 2004-1405 2004-1406 2004-1407 2004-1408 2004-1411/1000-400 2004-1411/1000-401 2004-1491 2004-1492 2004-1493 2004-1494 2004-171 2004-172 2004-402 2004-403 2004-404 2004-405 2004-405/011-000 2004-406 2004-406/020-000 2004-407 2004-408 2004-409 2004-410 2004-433 2004-434 2004-435 2004-436 2004-437 2004-438 2004-439 2004-440 2004-511 2004-541 2004-549 2004-552 2004-553 2004-554 2004-555 2004-911 2004-911/1000-541 2004-911/1000-542 2004-911/1000-836 2004-911/1000-867
2004555, 2004 555
