Datasheet Wago 2020-210/135-000 — Даташит
2-проводная розетка; Пластина разгрузки натяжения; 1,5; 10-пол.
2-CONDUCTOR FEMALE CONNECTOR; ST | |||
2020-210/135-000 Wago | по запросу |
Actuation type | Open Tool Slot |
Цвет | gray |
Connectable conductor materials | Copper |
Country of origin | DE |
Габариты: глубина | 25 mm / 0.984 inch |
Fine-stranded conductor | 0.14 … 1.5 mm² / 24 … 16 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.5 mm² / 20 AWG |
Fire load | 0.489 MJ |
GTIN | 4050821222101 |
Height | 69 mm / 2.717 inch |
Marking level | Side marking |
Nominal cross section | 1 mm² |
Number of Poles | 10 |
Product Group | 18 (X-COM-System) |
Rated current | 13.5 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 500 В |
Solid conductor | 0.14 … 1.5 mm² / 24 … 16 AWG |
Solid conductor, push-in termination | 0.5 … 1.5 mm² / 20 … 16 AWG |
Strip length | 9 … 11 mm / 0.35 … 0.43 Inch |
Total number of connection points | 20 |
Total number of potentials | 10 |
Type of wiring | Front-entry wiring |
Вес | 28.25 г |
Ширина | 35.7 mm / 1.406 inch |
Серия: 2020 (100 из 263)
- 2020-204/000-038 2020-204/000-039 2020-204/124-000 2020-204/133-000 2020-204/143-000 2020-205 2020-205/000-036 2020-205/000-037 2020-205/000-038 2020-205/000-039 2020-205/124-000 2020-205/133-000 2020-205/143-000 2020-206 2020-206/000-036 2020-206/000-037 2020-206/000-038 2020-206/000-039 2020-206/133-000 2020-206/143-000 2020-207 2020-207/000-036 2020-207/000-037 2020-207/000-038 2020-207/000-039 2020-207/124-000 2020-207/134-000 2020-207/144-000 2020-208 2020-208/000-036 2020-208/000-037 2020-208/000-038 2020-208/000-039 2020-208/124-000 2020-208/134-000 2020-208/144-000 2020-209 2020-209/000-036 2020-209/000-037 2020-209/000-038 2020-209/000-039 2020-209/124-000 2020-209/134-000 2020-209/144-000 2020-210 2020-210/000-036 2020-210/000-037 2020-210/000-038 2020-210/000-039 2020-210/125-000 2020-210/135-000 2020-210/145-000 2020-211 2020-211/000-036 2020-211/000-037 2020-211/000-038 2020-211/000-039 2020-211/125-000 2020-211/135-000 2020-211/145-000 2020-212 2020-212/000-036 2020-212/000-037 2020-212/000-038 2020-212/000-039 2020-212/125-000 2020-212/135-000 2020-212/145-000 2020-213 2020-213/000-036 2020-213/000-037 2020-213/000-038 2020-213/000-039 2020-213/125-000 2020-213/135-000 2020-213/145-000 2020-214 2020-214/000-036 2020-214/000-037 2020-214/000-038 2020-214/000-039 2020-214/125-000 2020-214/135-000 2020-214/145-000 2020-215 2020-215/000-036 2020-215/000-037 2020-215/000-038 2020-215/000-039 2020-215/125-000 2020-215/135-000 2020-215/145-000 2020-2201 2020-2202 2020-2203 2020-2204 2020-2207 2020-2208 2020-2209 2020-2217
- Rail / Chassis Terminal blocks | Pluggable Connection Systems
2020210/135000, 2020 210/135 000
