Datasheet Wago 2016-1208 — Даташит
Клеммная колодка для экрана; крепление на рейку; 2-проводная; ширина 12 мм; белая
2-CONDUCTOR SHIELD TERMINAL BLOC | |||
2016-1208 Wago | по запросу | ||
C2016-12-08 | по запросу |
Actuation type | Open Tool Slot |
Цвет | white |
Connectable conductor materials | Copper |
Country of origin | DE |
Габариты: глубина | 69.8 mm / 2.748 inch |
Design | horizontal |
Fine-stranded conductor | 0.5 … 25 mm² / 20 … 4 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 6 mm² / 14 AWG |
Fire load | 0.28 MJ |
GTIN | 4050821193739 |
Height from upper-edge of DIN-35 rail | 36.9 mm / 1.453 inch |
Marking level | Center/side marking |
Nominal cross section | 16 mm² |
Number of levels | 1 |
Product Group | 22 (TOPJOB S) |
Rated current CSA (Use Group B) | 80 A |
Rated current CSA (Use Group C) | 80 A |
Rated voltage CSA (Use Group B) | 600 В |
Rated voltage CSA (Use Group C) | 600 В |
Solid conductor | 0.5 … 16 mm² / 20 … 6 AWG |
Solid conductor, push-in termination | 6 … 16 mm² / 14 … 6 AWG |
Strip length | 18 … 20 mm / 0.71 … 0.79 Inch |
Total number of connection points | 2 |
Total number of potentials | 1 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 36.309 г |
Ширина | 12 mm / 0.472 inch |
Серия: 2016 (35)
- 2016-100 2016-115 2016-1201 2016-1202 2016-1204 2016-1207 2016-1208 2016-1291 2016-1292 2016-1301 2016-1302 2016-1303 2016-1304 2016-1305 2016-1306 2016-1307 2016-1391 2016-1392 2016-402 2016-403 2016-404 2016-405 2016-405/011-000 2016-433 2016-434 2016-435 2016-499 2016-511 2016-549 2016-7111 2016-7192 2016-7691 2016-7692 2016-7711 2016-7792
20161208, 2016 1208
