Datasheet Wago 2020-104/000-037 — Даташит
Серия2020
Модель2020-104/000-037
1-проводниковая розетка; 1,5; 4-пол.
Actuation typeOpen Tool Slot
Цветgreen-yellow, gray
Country of originDE
Габариты: глубина22.4 mm / 0.882 inch
Fine-stranded conductor0.14 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.5 mm² / 20 AWG
Fire load0.169 MJ
GTIN4050821026952
Height40.5 mm / 1.594 inch
Marking levelSide marking
Nominal cross section1 mm²
Number of Poles4
Product Group18 (X-COM-System)
Rated current13.5 A
Rated voltage (III / 3)500 В
Solid conductor0.14 … 1.5 mm² / 24 … 16 AWG
Solid conductor, push-in termination0.5 … 1.5 mm² / 20 … 16 AWG
Strip length9 … 11 mm / 0.35 … 0.43 Inch
Total number of connection points4
Total number of potentials4
Вес9.35 г
Ширина14.7 mm / 0.579 inch
Серия: 2020 (100 из 263)
  • Rail / Chassis Terminal blocks | Pluggable Connection Systems
2020104/000037, 2020 104/000 037
На английском языке: Datasheet Wago 2020-104/000-037
