Datasheet Wago 2022-1401/999-953 — Даташит
2-проводная/2-контактная несущая клеммная колодка; подходит для применений Ex nA; для DIN-рейки 35 x 15 и 35 x 7,5; 2,5 мм²; Push-in CAGE CLAMP
![]() 16 предложений от 5 поставщиков 2-CONDUCTOR/2-PIN CARRIER TERMIN | |||
2022-1401 | от 387 ₽ | ||
2022-1401 Wago | от 451 ₽ | ||
2022-1401 Wago | 498 ₽ | ||
20221401 | 14 768 ₽ |
Actuation type | Operating tool Push-in |
Цвет | gray |
Connectable conductor materials | Copper |
Country of origin | CN |
Габариты: глубина | 86.2 mm / 3.394 inch |
Design | horizontal |
Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
Fire load | 0.181 MJ |
GTIN | 4050821644798 |
Height from upper-edge of DIN-35 rail | 32.5 mm / 1.28 inch |
Marking level | Center/side marking |
Nominal cross section | 2.5 mm² |
Number of levels | 1 |
Rated voltage EN (Ex e II) | 630 В |
Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
Total number of connection points | 2 |
Total number of potentials | 1 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 9.072 г |
Ширина | 5.2 mm / 0.205 inch |
Серия: 2022 (100 из 251)
- 2022-112/000-039 2022-112/126-000 2022-112/136-000 2022-112/146-000 2022-113 2022-113/000-006 2022-113/000-012 2022-113/000-016 2022-113/000-037 2022-113/000-039 2022-113/126-000 2022-113/136-000 2022-113/146-000 2022-114 2022-114/000-006 2022-114/000-012 2022-114/000-016 2022-114/000-037 2022-114/000-039 2022-114/126-000 2022-114/136-000 2022-114/146-000 2022-115 2022-115/000-006 2022-115/000-012 2022-115/000-016 2022-115/000-037 2022-115/000-039 2022-115/127-000 2022-115/137-000 2022-115/147-000 2022-1201 2022-1201/999-953 2022-1202 2022-1204 2022-1204/999-953 2022-1207 2022-1207/999-953 2022-1291 2022-1292 2022-1301 2022-1301/999-953 2022-1302 2022-1304 2022-1304/999-953 2022-1307 2022-1307/999-953 2022-1391 2022-1392 2022-1401 2022-1401/999-953 2022-1402 2022-1404 2022-1404/999-953 2022-1407 2022-1407/999-953 2022-141 2022-142 2022-1491 2022-1492 2022-151 2022-152 2022-161 2022-162 2022-164 2022-167 2022-171 2022-172 2022-174 2022-177 2022-181 2022-182 2022-184 2022-187 2022-2201 2022-2201/999-953 2022-2202 2022-2202/999-953 2022-2203 2022-2203/999-953 2022-2204 2022-2204/999-953 2022-2207 2022-2207/999-953 2022-2208 2022-2208/999-953 2022-2209 2022-2209/999-953 2022-2217 2022-2217/999-953 2022-2227 2022-2227/999-953 2022-2231 2022-2231/999-953 2022-2232 2022-2232/999-953 2022-2233 2022-2233/999-953 2022-2234 2022-2234/999-953
20221401/999953, 2022 1401/999 953
