Datasheet Wago 2003-7651 — Даташит
Серия2003
Модель2003-7651
Многоуровневая монтажная клеммная колодка; 4 мм²; N; Push-in CAGE CLAMP
Actuation typePush-in Operating tool
Цветgray
Country of originDE
Габариты: глубина96 mm / 3.78 inch
Designangled
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
Fire load0.242 MJ
GTIN4045454735951
Height from upper-edge of DIN-35 rail42.3 mm / 1.665 inch
Marking levelCenter/side marking
Nominal cross section2.5 mm²
Number of levels3
Potential markingN
Product Group22 (TOPJOB S)
Rated current32 A
Rated voltage (III / 3)400 В
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points2
Total number of potentials1
Type of mountingDIN-35 rail
Вес9.753 г
Ширина5.2 mm / 0.205 inch
20037651, 2003 7651
На английском языке: Datasheet Wago 2003-7651
