Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet Wago 294-4435 — Даташит
Серия294
Модель294-4435
Разъем питания; с винтовым заземляющим контактом; без защелкивающихся монтажных ножек; DA+ DA- L PE N; 5-полюсный
Actuation typeOperating tool Push-button
Цветwhite
Connection technology 2PUSH WIRE®
Connection type (1)External 1
Connection type (2)Internal 2
Connection type (3)Internal 3
Connection type (4)Internal 4
Contact platingtin-plated
Country of originPL
Габариты: глубина27.3 mm / 1.075 inch
Fine-stranded conductor0.5 … 2.5 mm² / 18 … 14 AWG
Fine-stranded conductor with ferrule with plastic collar0.5 … 1.5 mm² / 18 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.5 … 1.5 mm² / 18 … 16 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.5 mm² / 18 AWG
Fine-stranded conductor with insulated ferrule (2)0.5 … 1 mm² / 18 … 16 AWG
Fine-stranded conductor with insulated ferrule (3)0.5 … 0.75 mm² / 18 AWG
Fine-stranded conductor with uninsulated ferrule (2)0.5 … 1.5 mm² / 18 … 14 AWG
Fine-stranded conductor with uninsulated ferrule (3)0.5 … 1 mm² / 18 AWG
Fire load0.301 MJ
GTIN4050821098102
Ground functionwith screw-type GND contact
Height from the surface17 mm / 0.669 inch
Insulating materialPolycarbonate (PC)
MarkingDA+ DA- L PE N
Material groupIII a
Number of Poles5
Number of connection points1
Number of connection points (connection type)2
Number of connection types4
Packaging typebag
Product Group8 (Misc. Chassis Mount Blocks)
Rated current24 A
Rated current (2)24 A
Rated current (3)16 A
Rated impulse voltage (II / 2) 24 kV
Rated voltage (II / 2)500 В
Rated voltage (II / 2) 2500 В
Ratings according to 2IEC/EN 60998-2-2
Ratings noteConnection points
Ratings note 2Connection points
Solid conductor0.5 … 2.5 mm² / 18 … 12 AWG
Solid conductor (2)0.5 … 2.5 mm² / 18 … 14 AWG
Solid conductor (3)0.5 … 1.5 mm² / 18 … 16 AWG
Solid conductor (4)0.5 … 0.75 mm² / 18 AWG
Solid conductor, push-in termination0.5 … 2.5 mm² / 18 … 12 AWG
Stranded conductor0.5 … 2.5 mm² / 18 … 14 AWG
Strip length (2)8 … 9 mm / 0.31 … 0.35 Inch
Temperature stability120 °C
Total number of connection points25
Total number of potentials5
Type of wiringSide-entry wiring
Вес15.77 г
Ширина50 mm / 1.969 inch
2944435, 294 4435
На английском языке: Datasheet Wago 294-4435
