Datasheet Wago 792-805 — Даташит
Клеммная колодка; IT MDHF 6; сети PROFIBUS; 5 В постоянного тока
![]() 5 предложений от 5 поставщиков 792-805, Клемма защиты от перенапряжений 5 В DC, для электрических цепей MDHF 5 | |||
792-805 Wago | 4 038 ₽ | ||
792-805 Wago | 27 751 ₽ | ||
M7928-05 | по запросу | ||
792-805 Wago | по запросу |
Capacity line/PG | ≤ 16 pF |
Capacity line/line | ≤ 19 pF |
Connections (number) | 5 |
Country of origin | DE |
Габариты: глубина | 91 mm / 3.583 inch |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 14 AWG |
GTIN | 4017332843737 |
Height from upper-edge of DIN-35 rail | 56 mm / 2.205 inch |
Impedance | 1 Ω |
Limit frequency line/line | 250 МГц |
Maximum continuous operating voltage | 4.2 VAC / 6 VDC |
Nominal current | 0.1 A |
Nominal discharge current (8/20 µs) in total | 10 kA |
Nominal discharge current (8/20 µs) per line | 5 kA |
Nominal operating voltage | 5 VDC |
Product Group | 21 (Special Products Electronic) |
Response time line/line | ≤ 1 ns |
Solid conductor | 0.08 … 2.5 mm² / 28 … 14 AWG |
Standards/specifications | IEC 61131-3 |
Surrounding air (operating) temperature | -40 … 80 °C |
Surrounding air (storage) temperature | -40 … 80 °C |
Type of mounting | DIN-35 rail |
Voltage protection level line/PG (cat. C2 at IN) | ≤ 50 V |
Voltage protection level line/PG (cat. C3 at IN) | ≤ 14 V |
Voltage protection level line/line (cat. C2 at IN) | ≤ 27 V |
Voltage protection level line/line (cat. C3 at IN) | ≤ 14 V |
Вес | 38 г |
Ширина | 6 mm / 0.236 inch |
