Datasheet Wago 2006-1201 — Даташит
Серия2006
Модель2006-1201
Клеммная колодка TOPJOB S проходная; монтаж на рейку; 2-проводная; ширина 7,5 мм; серая
26 предложений от 12 поставщиков
Bulk Metal?® Foil Technology Conformally Coated Precision Current Sensing Resistors with TCR of 5 ppm/?°C and values down to 5 m?©...
Триема
138 ₽
143 ₽
T-electron
20061201
12 649 ₽
2006-1201
Actuation typeOpen Tool Slot
Цветgray
Country of originDE
Габариты: глубина57.5 mm / 2.264 inch
Designhorizontal
Fine-stranded conductor0.5 … 10 mm² / 20 … 8 AWG
Fine-stranded conductor with ferrule, push-in termination, from2.5 mm² / 16 AWG
Fire load0.154 MJ
GTIN4017332999649
Height from upper-edge of DIN-35 rail32.9 mm / 1.295 inch
Marking levelCenter/side marking
Nominal cross section6 mm²
Number of levels1
Product Group22 (TOPJOB S)
Rated current (Ex e II)38 A
Rated current (Ex e II) with jumper33 A
Rated voltage EN (Ex e II)550 В
Solid conductor0.5 … 10 mm² / 20 … 8 AWG
Solid conductor, push-in termination2.5 … 10 mm² / 14 … 8 AWG
Strip length13 … 15 mm / 0.51 … 0.59 Inch
Total number of connection points2
Total number of potentials1
Type of mountingDIN-35 rail
Вес8.893 г
Ширина7.5 mm / 0.295 inch
20061201, 2006 1201
На английском языке: Datasheet Wago 2006-1201
