Datasheet Texas Instruments ADS7819P — Даташит
Серия | ADS7819 |
Модель | ADS7819P |
![Datasheet Texas Instruments ADS7819P](http://www.ti.com/graphics/folders/partimages/ADS7819.jpg)
12-битный КМОП аналого-цифровой преобразователь с частотой дискретизации 800 кГц 28-PDIP
Datasheet
Купить ADS7819P на РадиоЛоцман.Цены — от 992 до 66 469 ₽ 8 предложений от 8 поставщиков IC ADC 12BIT 28DIP | |||
ADS7819P | 992 ₽ | ||
ADS7819P Texas Instruments | 1 005 ₽ | ||
ADS7819P | 66 469 ₽ | ||
ADS7819P | по запросу |
Pin | 28 |
Package Type | NT |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Width (мм) | 6.73 |
Length (мм) | 35.69 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | ADS7810U |
Replacement Code | F |
RoHS | Не совместим |
- Tips for Using the ADS78xx Family of A/D ConvertersPDF, 24 Кб, Файл опубликован: 27 сен 2000
The input to each of the members of the ADS Family (ADS7804/05/06/07/08/09/10/19, so far) is a resistor divider network, converting the input signal to the range used internally. This resistor divider offers inherent overvoltage protection, which will often simplify analog circuitry. - Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Interleaving Analog-to-Digital ConvertersPDF, 64 Кб, Файл опубликован: 2 окт 2000
It is tempting when pushing the limits of analog-to-digital conversion to consider interleaving two or more converters to increase the sample rate. However, such designs must take into consideration several possible sources of error. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
- What Designers Should Know About Data Converter DriftPDF, 95 Кб, Файл опубликован: 2 окт 2000
Exactly how inaccurate will a change in temperature make an analog-to-digital or digital-to-analog converter? As designers are well aware, a 12-bit device may provide a much lower accuracy at its operating-temperature extremes, perhaps only to 9 or even 8 bits. But for lack of more precise knowledge, many play it safe (and expensive) and overspecify.
Серия: ADS7819 (6)
- ADS7819P ADS7819PB ADS7819U ADS7819U/1K ADS7819UB ADS7819UB/1K
- Semiconductors > Data Converters > Analog to Digital Converter > Precision ADC (<=10MSPS)
