Datasheet Texas Instruments TMP100NA/250 — Даташит
Серия | TMP100 |
Модель | TMP100NA/250 |
Датчик температуры с интерфейсом I2C/SMBus в SOT-23 6-SOT-23
TMP10x Temperature Sensor With I2C and SMBus Interface with Alert Function in SOT-23 Package datasheet
PDF, 948 Кб, Версия: I, Файл опубликован: 10 ноя 2015
![]() 38 предложений от 22 поставщиков Датчик температуры IC TEMP SENSOR DIGITAL SOT-23-6 * Texas Instruments -55°C ~ 125°C I?CTM/SMBusTM 2.7 V ~ 5.5 V... | |||
TMP100NA/250G4 Texas Instruments | 33 ₽ | ||
TMP100NA/250G4 Texas Instruments | 35 ₽ | ||
TMP100NA/250 Texas Instruments | 256 ₽ | ||
TMP100NA/250G4 Texas Instruments | по запросу |
Pin | 6 |
Package Type | DBV |
Industry STD Term | SOT-23 |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | T100 |
Width (мм) | 1.6 |
Length (мм) | 2.9 |
Thickness (мм) | 1.2 |
Pitch (мм) | .95 |
Max Height (мм) | 1.45 |
Mechanical Data | Скачать |
Addresses | 8 |
Interface | I2C, SMBus, 2-Wire |
Iq(Typ) | 45 uA |
Local Sensor Accuracy(Max) | 2 +/- C |
Package Group | SOT-23 |
Package Size: mm2:W x L | 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
Rating | Catalog |
Special Features | Configurable Resolution,One-Shot Conversion,Shutdown |
Supply Current(Max) | 75 uA |
Supply Current(Typ) | 45 uA |
Supply Voltage(Max) | 5.5 В |
Supply Voltage(Min) | 2.7 В |
Temp Resolution(Max) | 12 bits |
- Interfacing the MSP430 and TMP100 I2C Temperature SensorPDF, 74 Кб, Файл опубликован: 16 июл 2002
This application report describes the hardware and software interface between the Texas Instruments MSP430F413 16-bit micro-controller and TMP100 digital temperature sensor, implementing an ultra-low power temperature measurement system (Figure 1) capable of operation from a single 3-V battery for over 10 years. The following sections demonstrate how to interface the two devices in hardware as wel - Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: TMP100 (5)
- SN0312100DBVR TMP100NA/250 TMP100NA/250G4 TMP100NA/3K TMP100NA/3KG4
- Semiconductors > Sensing Products > Temperature Sensors > Local Digital Temperature Sensors
