Datasheet Texas Instruments SN74LS145N — Даташит
СерияSN74LS145
МодельSN74LS145N
Декодеры/драйверы преобразования BCD в десятичное число 16-PDIP от 0 до 70
BCD to Decimal Decoders/Drivers datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 1 мар 1974
62 предложений от 32 поставщиков
Микросхема Логический контроллер, TEXAS INSTRUMENTS SN74LS145N BCD to Decimal Decoder / Driver, LS Family, 10 Output, 80mA, 4.75V to 5.25V, DIP-16...
T-electron
SN74LS145N
35 ₽
SN74LS145N
от 72 ₽
SN74LS145N
110 ₽
SN74LS145N3
Pin16
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаSN74LS145N
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Полоса частот35 МГц
Bits10
Количество каналов1
Configuration4:10
Digital input leakage(Max)5 uA
ESD Charged Device Model0.75 kV
ESD HBM2 kV
F @ Nom Voltage(Max)35 Mhz
FunctionDecoder/Demultiplexer
ICC @ Nom Voltage(Max)13 мА
Output Drive (IOL/IOH)(Max)80/-20 мА
Package GroupPDIP
Schmitt TriggerNo
Technology FamilyLS
ТипStandard
VCC(Max)5.25 В
VCC(Min)4.75 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)50 нс
  • Hardware Design Considerations for a Wireless LED based Display Design
    PDF, 682 Кб, Файл опубликован: 11 июн 2014
    Scoreboards have different purposes with various features. Scoreboards are typically used for displaying scores of a game played between two teams. These games can be a timed or an untimed event. The application described in this application report creates a multi-sport scoreboard that is cost efficient, portable, and easy to use. The display values on the scoreboard are transmitted wirelessly.
  • Designing with the SN54/74LS123 (Rev. A)
    PDF, 118 Кб, Версия: A, Файл опубликован: 1 мар 1997
  • Semiconductors > Switches and Multiplexers > Buffered Encoders and Decoders
На английском языке: Datasheet Texas Instruments SN74LS145N
