Datasheet Texas Instruments MPC100AP — Даташит
СерияMPC100
МодельMPC100AP
Широкополосный видеомультиплексор 4X1 14-PDIP
Analog Multiplexer Single 4:1 14Pin PDIP
MPC100AP
5 395 ₽
MPC100AP
6 346 ₽
T-electron
MPC100AP
Allelco
MPC100AP
Burr-Brown
Pin14
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
RoHSНе совместим
  • Macromodels for RF Op Amps Are a Powerful Design Tool
    PDF, 68 Кб, Файл опубликован: 2 окт 2000
    The macromodel for the Diamond Transistor OPA660 gives an example of the structure and performance of these new Spice models.
  • The MPC100 Analog Multiplexer Improves RF Signal Distribution
    PDF, 131 Кб, Файл опубликован: 27 сен 2000
    The new 4 to 1 video multiplexer MPC100 opens the door to high-speed signal distribution without the headaches. This component contains four wideband open-loop amplifiers connected together internally
  • Multiplexer Data Acquisition System
    PDF, 71 Кб, Файл опубликован: 4 окт 2000
    Multiplexers have been used for acquisition of quasi-static signals for a long time. While these signals usually have a low bandwidth of only a few hertz, applications generally require that the multiplexer send each signal as fast as possible to the converter and that the signals be processed quickly. To ensure fast processing, such acquisition systems usually include a sense amplifier behind the
Серия: MPC100 (3)
  • Semiconductors > Switches and Multiplexers > Multiplexer/Demultiplexer (Mux/Demux) > Analog Mux/Demux
На английском языке: Datasheet Texas Instruments MPC100AP
