Datasheet Texas Instruments UC1903L — Даташит
Серия | UC1903 |
Модель | UC1903L |
Четырехканальный монитор питания и линии 20-LCCC от -55 до 125
Quad Supply and Line Monitor datasheet
PDF, 796 Кб, Версия: A, Файл опубликован: 26 авг 2008
![]() 14 предложений от 14 поставщиков Processor Supervisor Adj 4 Active Low/Open Drain 20-Pin CLLCC Tube | |||
UC1903L Texas Instruments | 2 871 ₽ | ||
UC1903L Texas Instruments | 3 953 ₽ | ||
UC1903L883BC Texas Instruments | по запросу | ||
UC1903L/883BC Texas Instruments | по запросу |
Pin | 20 |
Package Type | FK |
Industry STD Term | LCCC |
JEDEC Code | S-CQCC-N |
Package QTY | 1 |
Carrier | TUBE |
Маркировка | UC1903L |
Width (мм) | 8.89 |
Length (мм) | 8.89 |
Thickness (мм) | 1.83 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.03 |
Mechanical Data | Скачать |
# of Supplies Monitored | 4 |
Iq(Typ) | 7000 uA |
Monitored Voltage 1 (typ)(Nom) | Adjustable В |
Output Driver Type / Reset Output | Active-low,Open-drain |
Package Group | LCCC |
Package Size: mm2:W x L | 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG |
Rating | Military |
Reset Threshold Accuracy | 3 % |
Special Features | Negative Voltage Monitoring,Over Voltage Sense |
Threshold Voltage 1(Typ) | 1.8 В |
Threshold Voltage 2 (typ)(Typ) | Adjustable В |
Time Delay | Programmable ms |
VCC(Max) | 40 В |
VCC(Min) | 8 В |
Watchdog Timer WDI | None sec |
RoHS | See ti.com |
- DN-33 Optocoupler Feedback Drive Techniques Using the UC3901 and UC3903PDF, 45 Кб, Файл опубликован: 5 сен 1999
A variety of low-cost supervisory ICs contain the required building blocks for the more demanding optocoupler feedback drive applications. Initially developed to address other specific power supply tasks several control ICs excel in the role as precision optocoupler control and drivers. This design note describes a basic optocoupler driver circuit and also a more advanced optocoupler drive circ - Optimizing Resistor Dividers at a Comparator (Rev. A)PDF, 120 Кб, Версия: A, Файл опубликован: 3 июн 2013
- Choosing an Appropriate Pull-up/Pull-down Resistor for Open Drain OutputsPDF, 130 Кб, Файл опубликован: 19 сен 2011
Серия: UC1903 (6)
- Semiconductors > Space & High Reliability > Power Management Products > Supervisor and Reset ICs
