Datasheet Texas Instruments TSC2102IDA — Даташит
СерияTSC2102
МодельTSC2102IDA
4-проводной контроллер сенсорного экрана со стерео ЦАП и усилителем HP 32-TSSOP -40 to 85
Programmable Touch Screen Controller w/Integrat Stereo Audio DAC & Headphone Amp datasheet
PDF, 720 Кб, Версия: A, Файл опубликован: 17 июн 2004
Активная деталь, 4-Wire Touch Screen Controller with Stereo DAC with HP Amplifier 32-TSSOP -40℃ to 85℃
TSC2102IDA
148 ₽
727GS
TSC2102IDA
219 ₽
TSC2102IDA
268 ₽
TSC2102IDA
Pin32
Package TypeDA
Industry STD TermTSSOP
Package QTY46
МаркировкаTSC2102I
Width (мм)6.2
Length (мм)11
Thickness (мм)1.15
Max Height (мм)1.2
# Audio DACs / ADCs2 / 0
Additional FeaturesInt. PLL
Analog Supply2.7 - 3.6 В
Audio Codec Resolution24 Bits
Audio Pd11 mW
Audio Sample Rate53 ksps
Control InterfaceSPI
Digital Audio InterfaceI2S,R,L,DSP
Digital Supply (up to 5 V)1.525 - 1.95 В
IO Supply1.1 - 3.6 В
Number of Audio Inputs / Outputs0 / 2
Package GroupTSSOP
Package Size: mm2:W x L32TSSOP: 89 mm2: 8.1 x 11(TSSOP) PKG
SAR ADC Resolution12 Bits
SAR Sample Rate(Max)125 kSPS
SNR Audio DAC / ADC(Typ)96 / - дБ
Touch Panel4-Wire
VrefInt Int/Ext
  • TSC2100 WinCE Generic Drivers
    PDF, 206 Кб, Файл опубликован: 8 мар 2004
    This application report develops and presents the TSC2100 touchscreen and audio WinCE drivers. These generic drivers can be used on or adapted to different processors or processor platforms. The associated driver code was tested with the Intel(TM) Lubbock and MainStone platforms.
  • Using the PGA Function in TSC210x/AIC26/AIC28/DAC26 Devices
    PDF, 453 Кб, Файл опубликован: 3 июн 2005
    TI's touch screen and audio codec/DAC devices, such as the TSC2100, TSC2101, TSC2102, TLV320AIC26, TLV320AIC28, and the TLC320DAC26, have one or more audio-band programmable gain amplifiers (PGA) in their input circuitry. This application report describes how to implement this PGA function using the TLV320DAC26 as an example.
  • Programming Audio Power Up/Down on TSC210x & TLV320AIC26/28 (Rev. A)
    PDF, 61 Кб, Версия: A, Файл опубликован: 5 май 2005
    This application report presents some general and practical programming sequences for the audio power up/down of Texas Instruments TSC2100/TSC2102/TLV320AIC26 and TSC2101/TLV320AIC28 devices, so as to avoid a possible malfunction or errors during and after power up or down.
  • Programming Sequences and Tips for TSC2000/2200/230x Applications
    To apply the touchscreen function of a TSC2000, TSC2200, or TSC230x device, certain software programming sequences are crucial during the TSC initialization and data reading and are also helpful during the TSC mode changing. This application report presents some practical programming sequences. Additionally, some program and debug tips are provided.
  • Interface TSC Through McBSP
    PDF, 221 Кб, Файл опубликован: 28 окт 2004
    This application report develops and presents the methodology to interface TI's touch screen controller products and multichannel buffered serial ports (McBSP) through SPI and I2S buses. The interface software code is designed and tested using the TMS320VC5416 DSK and the TSC2100 EVM.
  • How to Set the TSC/AIC EVM to Record & Playback Audio or Other Sound Through PC
    PDF, 480 Кб, Файл опубликован: 14 дек 2004
    Record and playback audio, sound, or voice on a TI touch screen controller (TSC) or audio codec (AIC) EVM system by means of the associated software running on a PC system. The PC and EVM are connected using a USB cable. This application report gives an example to demonstrate how to do this through a Windows XP? PC system. The block diagram and connection are shown in Figure 1.
Серия: TSC2102 (2)
  • Semiconductors > Audio > Touch Screen Controller with Audio
На английском языке: Datasheet Texas Instruments TSC2102IDA
