Datasheet Texas Instruments TPS65176RHDT — Даташит
Серия | TPS65176 |
Модель | TPS65176RHDT |
ЖК-дисплей смещения ИС для телевизора 28-VQFN -40 до 85
LCD Bias Integrated Circuit for TV datasheet
PDF, 699 Кб, Файл опубликован: 16 окт 2012
Купить TPS65176RHDT на РадиоЛоцман.Цены — от 23 до 410 ₽ 34 предложений от 14 поставщиков TEXAS INSTRUMENTS TPS65176RHDT LCD BIAS, TV, 28VQFN | |||
TPS65176RHDT Texas Instruments | от 23 ₽ | ||
TPS65176RHDT Texas Instruments | 150 ₽ | ||
TPS65176RHDT Texas Instruments | 173 ₽ | ||
TPS65176RHDT Texas Instruments | по запросу |
Pin | 28 |
Package Type | RHD |
Industry STD Term | VQFN |
JEDEC Code | S-PQFP-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Width (мм) | 5 |
Length (мм) | 5 |
Thickness (мм) | 0.9 |
Pitch (мм) | 0.5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
DisplayType | LCD Unipolar |
IC Integration | LCD Bias |
Pin/Package | 28VQFN |
Source Driver Voltage(Max) | 18.5 В |
Source Driver Voltage(Min) | 13.7 В |
Special Function | Reset Generator |
Target Application | 13 to 21 inches,21 inches and above |
Topology | Boost,Buck |
Vin(Max) | 14 В |
Vin(Min) | 9.5 В |
- Generation of a VCOM buffer input using PWM signalPDF, 439 Кб, Файл опубликован: 21 дек 2015
In an LCD the backlight shines through the liquid crystal material and the voltage across the liquid crystal controls how much light shines through it. An active matrix LCD (AMLCD) contains many pixels arranged in a grid pattern. The voltage across each pixel is controlled individually so that high resolution images can be created. One terminal of every pixel is connected to a common plane. The v - Understanding Undervoltage Lockout in Power Devices (Rev. A)PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products. - Minimizing Ringing at the Switch Node of a Boost ConverterPDF, 201 Кб, Файл опубликован: 15 сен 2006
The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter. - Basic Calculation of a Boost Converter's Power Stage (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS65176 (2)
- TPS65176RHDR TPS65176RHDT
- Semiconductors > Power Management > LCD/OLED Display Bias Solutions
