Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet Texas Instruments TPS54872PWPRG4 — Даташит
СерияTPS54872
МодельTPS54872PWPRG4
8A Активное окончание шины/DC-преобразователь памяти DDR 28-HTSSOP -40 to 85
8-A Output, 4-V to 6-V Input Tracking/Termination Synchronous PWM Switcher datasheet
PDF, 682 Кб, Версия: C, Файл опубликован: 11 фев 2005
Conv DC-DC 4V to 6V Step Down Single-Out 0.2V to 3.3V 8A 28Pin HTSSOP EP T/R
TPS54872PWPRG4
415 ₽
T-electron
TPS54872PWPRG4
567 ₽
TPS54872PWPRG4
707 ₽
HXD Co.
TPS54872PWPRG4
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаTPS54872
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Control ModeVoltage Mode
DDR Memory TypeDDR,DDR2,DDR3
Iout VTT(Max)8 A
Iq(Typ)11 мА
OutputVTT
Package GroupHTSSOP
Package Size: mm2:W x L28HTSSOP: 62 mm2: 6.4 x 9.7(HTSSOP) PKG
Regulator TypeStep-Down Converter
Special FeaturesStatus Pin
Vin Bias(Max)6 В
Vin Bias(Min)4 В
Vin(Max)6 В
Vin(Min)4 В
Vout VTT(Min)0.2 В
  • Evaluation Modules & Boards: TPS54872EVM-222
    8-A Active Bus Termination/DDR Memory DC/DC Converter
  • Evaluation Modules & Boards: XILINXPWR-082
    XILINXPWR-082 Power Management Evaluation Module for Xilinx FPGAs
  • Dual Output Power Supply Sequencing for High Performance Processors
    PDF, 6.0 Мб, Файл опубликован: 17 июл 2002
    Dual voltage power supply architectures are becoming commonplace in high performance microprocessor and digital signal processor (DSP) systems. To save power and increase processing speeds, processor cores have smaller geometry cells and require lower supply voltages than the system bus voltages. Power management in these systems requires special attention. Yesterday's power management ICs and app
  • Using Low Voltage SWIFT DC/DC Converters with Ceramic Capacitors
    PDF, 490 Кб, Файл опубликован: 8 янв 2003
    This application note investigates an adequate phase margin for stable operation of SWIFTв„ў regulators with the ceramic capacitors at worst-case tolerances of regulator and external parts. TI also shows how the bandwidth and gain of feedback loop impact on load-current transient-response characteristics. Measurements and analysis have shown that the voltage-mode control SWIFTв„ў regulat
Серия: TPS54872 (4)
  • Semiconductors > Power Management > DDR Memory Power Solutions
На английском языке: Datasheet Texas Instruments TPS54872PWPRG4
