Datasheet Texas Instruments TPS3851G18EDRBR — Даташит
Серия | TPS3851 |
Модель | TPS3851G18EDRBR |
Высокоточный регулятор напряжения со встроенным сторожевым таймером 8-SON -40 до 125
TPS3851 Precision Voltage Supervisor with Integrated Watchdog Timer datasheet
PDF, 1.2 Мб, Файл опубликован: 16 ноя 2016
![]() 24 предложений от 12 поставщиков Чип контроля напряжения, High-Accuracy Voltage Supervisor With Integrated Watchdog Timer 8-SON -40℃ to 125℃ | |||
TPS3851G18EDRBR Texas Instruments | от 64 ₽ | ||
TPS3851G18EDRBR Texas Instruments | от 118 ₽ | ||
TPS3851G18EDRBR Texas Instruments | 119 ₽ | ||
TPS3851G18EDRBR Texas Instruments | 188 ₽ |
Pin | 8 |
Package Type | DRB |
Industry STD Term | VSON |
JEDEC Code | S-PDSO-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | 851DD |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .88 |
Pitch (мм) | .65 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
# of Supplies Monitored | 1 |
Iq(Typ) | 10 uA |
Monitored Voltage 1 (typ)(Nom) | 1.8,2.5,3,3.3,5 В |
Monitored Voltage 2 (typ)(Nom) | N/A В |
Output Driver Type / Reset Output | Active-low,Open-drain |
Package Group | SON |
Package Size: mm2:W x L | See datasheet (SON) PKG |
Rating | Catalog |
Reset Threshold Accuracy | 0.8 % |
Special Features | Active Low Enable,Manual Reset,Watchdog Disable,Watchdog Timer |
Threshold Voltage 1(Typ) | 1.67,1.73,2.32,2.4,2.79,2.88,3.07,3.17,4.65,4.8 В |
Threshold Voltage 2 (typ)(Typ) | N/A В |
Time Delay | 200 ms |
VCC(Max) | 6.5 В |
VCC(Min) | 1.6 В |
Watchdog Timer WDI | Programmable sec |
- Evaluation Modules & Boards: TPS3851EVM-780
TPS3851 High-Accuracy Supervisor with Window Watchdog Evaluation Module
Серия: TPS3851 (26)
- TPS3851G18EDRBR TPS3851G18EDRBT TPS3851G18SDRBR TPS3851G18SDRBT TPS3851G25EDRBR TPS3851G25EDRBT TPS3851G30EDRBR TPS3851G30EDRBT TPS3851G33EDRBR TPS3851G33EDRBT TPS3851G33SDRBR TPS3851G33SDRBT TPS3851G50EDRBR TPS3851G50EDRBT TPS3851G50SDRBR TPS3851G50SDRBT TPS3851H18EDRBR TPS3851H18EDRBT TPS3851H25EDRBR TPS3851H25EDRBT TPS3851H30EDRBR TPS3851H30EDRBT TPS3851H33EDRBR TPS3851H33EDRBT TPS3851H50EDRBR TPS3851H50EDRBT
- Semiconductors > Power Management > Supervisor and Reset IC
