Datasheet Texas Instruments TPS3103K33DBVRG4 — Даташит
СерияTPS3103
МодельTPS3103K33DBVRG4
Сверхнизкий ток питания, контрольные цепи напряжения 6-SOT-23 -40 до 85
TPS31xx Ultralow Supply-Current Voltage Monitor With Optional Watchdog datasheet
PDF, 1.0 Мб, Версия: G, Файл опубликован: 28 сен 2016
Контрольный чип источника питания, 2.941V Supply Voltage Supervisor 0V to 3.6V 1 Active Low/Open Drain 6Pin SOT-23 T/R
TPS3103K33DBVRG4
139 ₽
TPS3103K33DBVRG4
211 ₽
TPS3103K33DBVRG4
543 ₽
TPS3103K33DBVRG4
Pin6
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаPGRI
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
# of Supplies Monitored2
Iq(Typ)1.2 uA
Monitored Voltage 1 (typ)(Nom)1.2,1.5,2,3.3 В
Monitored Voltage 2 (typ)(Nom)N/A В
Output Driver Type / Reset OutputActive-low,Open-drain
Package GroupSOT-23
Package Size: mm2:W x L6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Reset Threshold Accuracy1.5 %
Special FeaturesActive Low Enable,Manual Reset
Threshold Voltage 1(Typ)1.14,1.43,1.84,2.94 В
Threshold Voltage 2 (typ)(Typ)N/A В
Time Delay130 ms
VCC(Max)3.6 В
VCC(Min)0.9 В
Watchdog Timer WDINone sec
  • Monitoring Five Different Voltage Rails Using the TPS3103 and TPS3306
    PDF, 125 Кб, Файл опубликован: 28 авг 2003
    As portable power designs get more complex, the number of power supply rails are increasing. Finding a simple supervisor circuit to monitor all the voltage rails can be complicated due to the number of different rail voltages and desired SVS trip voltages. To provide a solution for the more complex designs, the TPS3103 and TPS3306 can be used to monitor up to five different voltage rails. This des
  • Semiconductors > Power Management > Supervisor and Reset IC
На английском языке: Datasheet Texas Instruments TPS3103K33DBVRG4
