Datasheet Texas Instruments TPS2051DG4 — Даташит
СерияTPS2051
МодельTPS2051DG4
0,7 А, 2,7–5,5 В, одиночный МОП-транзистор Hi-Side, отчет об ошибках, включение Act-High, 8-SOIC от -40 до 85
TPS2041, TPS2051 - Power-Distribution Switches datasheet
PDF, 574 Кб, Версия: A, Файл опубликован: 14 окт 1998
USB Power SW USB Power Switch Single 5.5V 0.9A 8Pin SOIC Tube
T-electron
TPS2051DG4
211 ₽
TPS2051DG4
228 ₽
TPS2051DG4
279 ₽
ТаймЧипс
TPS2051DG4
Package TypeD
Package QTY75
Маркировка2051
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
  • TPS3801/09 - Smallest SVS for Monitoring DSPs and Processors
    PDF, 185 Кб, Файл опубликован: 2 сен 1999
    This application report describes the TPS3801 and TPS3809 supply voltage supervisor (SVS) families of devices. The report gives a general introduction to reset generators followed by an overview of the technical parameters and the special features of the TPS380x. Each feature is discussed separately. Measurements make it easy to understand SVS principles of operation. Typical applications that inc
  • TPS202x/3x And TPS204x/5x USB Power Distribution
    PDF, 116 Кб, Файл опубликован: 16 окт 1998
    The USB specification, revision 1.1, defines the power distribution requirements for the self-powered hubs (including hosts), bus-powered hubs, and functions. This application report demonstrates how Texas Instruments power management products meet or exceed voltage regulation, voltage droop, and EMI requirements in the USB power distribution system.
  • A Power-Distribution Switch With Latched Over-Current Protection (Rev. A)
    PDF, 99 Кб, Версия: A, Файл опубликован: 3 июл 2007
    Power-distribution switches, like the TPS203x, operate in retry mode in an overload, but some applications require the switch to latch off. The latch-off function can be implemented using the simple circuit described in this application report.
Серия: TPS2051 (4)
  • Semiconductors > Power Management > USB Power and Charging Port Controllers > Fixed Current Limited Switch
На английском языке: Datasheet Texas Instruments TPS2051DG4
