Datasheet Texas Instruments HPA00030DAPR — Даташит
Серия | TLC5923 |
Модель | HPA00030DAPR |
16-канальный светодиодный драйвер с коррекцией точек 32-HTSSOP от -40 до 85
TLC5923 16 Channel LED Driver With DOT Correction datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 31 янв 2013
![]() 5 предложений от 5 поставщиков Чип стабилизации напряжения, Switching Controllers Order MFG part # TLC5923DAPR | |||
HPA00030DAPR Texas Instruments | 104 ₽ | ||
HPA00030DAPR Texas Instruments | 138 ₽ | ||
HPA00030DAPR | по запросу | ||
HPA00030DAPR Texas Instruments | по запросу |
Pin | 32 |
Package Type | DAP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | TLC5923 |
Width (мм) | 6.2 |
Length (мм) | 11 |
Thickness (мм) | 1.15 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Analog Dimming Steps | 128 |
Ch to Ch Accuracy(Typ) | 1 +/- % |
Data Transfer Rate(Typ) | 30 МГц |
Package Group | HTSSOP |
Package Size: mm2:W x L | 32HTSSOP: 89 mm2: 8.1 x 11(HTSSOP) PKG |
Rating | Catalog |
Special Features | Error Flag,Fault Detection,LED Open Detection,Power Good |
- LED Driver--Paralleled Outputs Provide High Current OutputsPDF, 957 Кб, Файл опубликован: 25 сен 2006
This application report describes how to use the TLC5922, TLC5923, and TLC5924 to drive high-current LEDs. These ICs are designed to provide 16 individually controllable constant-current sinks. However, the 16 outputs can be connected in parallel to increase the current drive capability. Paralleling the outputs of these ICs allows the TLC5922, TLC5923, and TLC5924 to drive high-power LEDs such as
Серия: TLC5923 (9)
- Semiconductors > Power Management > LED Driver > Signage & Large Display LED Driver
