Datasheet Texas Instruments HPA00025S8 — Даташит
Серия | SN74SSTVF16859 |
Модель | HPA00025S8 |
Регистровый буфер от 13 до 26 бит с входами и выходами SSTL_2 56-VQFN от 0 до 70
SN74SSTVF16859 datasheet
PDF, 891 Кб, Версия: B, Файл опубликован: 30 янв 2004
Купить HPA00025S8 на РадиоЛоцман.Цены — от 335 до 432 ₽ 13Bit to 26Bit Registered Buffer with SSTL_2 Inputs and Outputs 56-VQFN 0 to 70 | |||
HPA00025S8 Texas Instruments | 335 ₽ | ||
HPA00025S8 Texas Instruments | 432 ₽ |
Pin | 56 |
Package Type | RGQ |
Industry STD Term | VQFNP |
JEDEC Code | S-PQFP-N |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | SSF859 |
Width (мм) | 8 |
Length (мм) | 8 |
Thickness (мм) | .93 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Absolute Jitter (Peak-to-Peak Cycle or Period Jitter) | N/A ps |
Function | DDR Register |
Количество выходов | 26 |
Operating Frequency Range(Max) | 500 МГц |
Рабочий диапазон температур | от 0 до 70 C |
Output Drive | 16 мА |
Package Group | VQFN |
Package Size: mm2:W x L | 56VQFN: 64 mm2: 8 x 8(VQFN) PKG |
Rating | Catalog |
VCC | 2.5 В |
t(phase error) | N/A ps |
tsk(o) | N/A ps |
- 56-Pin Quad Flatpack No-Lead Logic PackagePDF, 275 Кб, Файл опубликован: 7 фев 2003
Texas Instruments (TI) Quad Flatpack No-Lead (QFN) 56-terminal package complies with JEDEC standard MO-220, allows for board miniaturization, and holds several advantages over traditional SOIC, TQFP, TSSOP, and TVSOP packaging. This package, designated RGQ by TI, physically is smaller than traditional leaded solutions, has a smaller routing area, improved thermal performance, and improved electric - Application of the SN74SSTV32852 in Stacked, Low-Profile (1U) PC-1600/2100 DIMMsPDF, 445 Кб, Файл опубликован: 7 ноя 2001
Many memory-module manufacturers are turning to low-profile (1U) DIMM designs that significantly increase memory density in computer workstations and servers. The reduction in DIMM height consequently affects the design and layout of the boards. The stacked 1U DIMMs present a unique and challenging problem due partly to the reduction in area for mounting components and also due to the load. The TI - Application of the SN74SSTVF16857 in Planar PC2700 (DDR-333) RDIMMsPDF, 359 Кб, Файл опубликован: 10 янв 2003
The high-capacity memory modules used in servers and workstations present a complex load to the memory controller used in these high-reliability, high-performance systems. To meet the demands of stable functionality over a broad spectrum of operating environments and system timing needs, and to support data integrity, these dual in-line memory modules (DIMMs) require the use of registers in the ad - Low-Power Support Using Texas Instruments SN74SSTV16857 and SN74SSTV16859PDF, 138 Кб, Файл опубликован: 9 фев 2001
The Texas Instruments SN74SSTV16857 and SN74SSTV16859 registers support the low-power mode of the DDR-DIMM. This application report explains the low-power mode and the features of the registers that support the low-power mode. Also, the considerations that the system designer must be aware of when implementing the low-power state of a registered memory module are explained. The sequence that must
Серия: SN74SSTVF16859 (7)
- Semiconductors > Clock and Timing > Memory Interface Clocks and Registers
