Источники питания Keen Side
Datasheet Intersil ISL12026A — Даташит
ПроизводительIntersil
СерияISL12026A
Часы/календарь реального времени с шиной I 2 C и EEPROM
ISL12026, ISL12026A Datasheet
PDF, 1.0 Мб, Версия: 2017-11-20
Часы реального времени REAL TIME CLK/CLNDR W/EEPROM IN 8LD
TradeElectronics
ISL12026A
Intersil
ISL12026AIBZISL12026AIBZ-TISL12026AIVZISL12026AIVZ-T
N1234
Корпус8 Ld SOIC8 Ld SOIC T+R8 Ld TSSOP8 Ld TSSOP T+R
Parameters / ModelsISL12026AIBZISL12026AIBZ-TISL12026AIVZISL12026AIVZ-T
Alarms2222
Battery BackupYesYesYesYes
Battery SealYesYesYesYes
CPU Supervisory Function PORNoNoNoNo
CPU Supervisory Function Watchdog TimerNoNoNoNo
Crystal Frequency TrimmingYesYesYesYes
DescriptionReal Time Clock/Calendar with I2C Bus? and EEPROMReal Time Clock/Calendar with I2C Bus? and EEPROMReal Time Clock/Calendar with I2C Bus? and EEPROMReal Time Clock/Calendar with I2C Bus? and EEPROM
FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUT
Freq. Out PinYesYesYesYes
IBAT850 nA850 nA850 nA850 nA
IRQ PinYesYesYesYes
IRQ_BarIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUT
Memory TypeEEPROMEEPROMEEPROMEEPROM
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85
Oscillator Compensation (ppm)-64 to +110-64 to +110-64 to +110-64 to +110
Peak Temp260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandard
RESET_barNoNoNoNo
ResetNoNoNoNo
SRAM512x8-Bit EEPROM512x8-Bit EEPROM512x8-Bit EEPROM512x8-Bit EEPROM
Selectable Frequency Output3333
Tamper DetectNoNoNoNo
Time Keeping Current5 μA5 μA5 μA5 μA
TimerNoNoNoNo
VBAT (max)5.5 V5.5 V5.5 V5.5 V
VBAT (min)1.8 V1.8 V1.8 V1.8 V
VCC (max)5.5 V5.5 V5.5 V5.5 V
VCC (min)2.7 V2.7 V2.7 V2.7 V
ИнтерфейсI2CI2CI2CI2C
RoHSСовместимСовместимСовместимСовместим
ISL12026
  • Timing & Digital ICs > Real Time Clocks > Real Time Clocks
На английском языке: Datasheet Intersil ISL12026A
