Datasheet Intersil ISL12058 — Даташит
Производитель | Intersil |
Серия | ISL12058 |
Низкая стоимость, малое энергопотребление I 2 Часы реального времени/календарь с шиной C-Bus Низкое энергопотребление и недорогие часы реального времени с функцией будильника
![]() 41 предложений от 22 поставщиков Интегральные микросхемы Тактовые микросхемы - Генераторы реального времени | |||
ISL12058IBZ Renesas | 29 ₽ | ||
ISL12058IUZ Intersil | от 117 ₽ | ||
ISL12058IRTZ Intersil | от 1 794 ₽ | ||
ISL12058IBZ Intersil | по запросу |
ISL12058IBZ | ISL12058IBZ-T | ISL12058IRTZ | ISL12058IRTZ-T | ISL12058IRUZ-T | ISL12058IUZ | ISL12058IUZ-T | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld DFN | 8 Ld DFN T+R | 8 Ld uTDFN T+R | 8 Ld MSOP | 8 Ld MSOP T+R |
Parameters / Models | ISL12058IBZ | ISL12058IBZ-T | ISL12058IRTZ | ISL12058IRTZ-T | ISL12058IRUZ-T | ISL12058IUZ | ISL12058IUZ-T |
Alarms | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Battery Backup | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
Battery Seal | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
CPU Supervisory Function POR | No | No | No | No | No | No | No |
CPU Supervisory Function Watchdog Timer | No | No | No | No | No | No | No |
Description | Low Cost, Low Power I2C-Bus? Real Time Clock/Calendar Low Power and Low Cost RTC with Alarm Function | Low Cost, Low Power I2C-Bus? Real Time Clock/Calendar Low Power and Low Cost RTC with Alarm Function | Low Cost, Low Power I2C-Bus? Real Time Clock/Calendar Low Power and Low Cost RTC with Alarm Function | Low Cost, Low Power I2C-Bus? Real Time Clock/Calendar Low Power and Low Cost RTC with Alarm Function | Low Cost, Low Power I2C-Bus? Real Time Clock/Calendar Low Power and Low Cost RTC with Alarm Function | Low Cost, Low Power I2C-Bus? Real Time Clock/Calendar Low Power and Low Cost RTC with Alarm Function | Low Cost, Low Power I2C-Bus? Real Time Clock/Calendar Low Power and Low Cost RTC with Alarm Function |
FOUT | IRQ_bar/FOUT | IRQ_bar/FOUT | IRQ_bar/FOUT | IRQ_bar/FOUT | IRQ_bar/FOUT | IRQ_bar/FOUT | IRQ_bar/FOUT |
Freq. Out Pin | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
IRQ Pin | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
IRQ_Bar | IRQ1/FOUT | IRQ1/FOUT | IRQ1/FOUT | IRQ1/FOUT | IRQ1/FOUT | IRQ1/FOUT | IRQ1/FOUT |
Memory Type | RAM | RAM | RAM | RAM | RAM | RAM | RAM |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Other Functions | Dual Alarms | Dual Alarms | Dual Alarms | Dual Alarms | Dual Alarms | Dual Alarms | Dual Alarms |
Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Reset | No | No | No | No | No | No | No |
Selectable Frequency Output | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Tamper Detect | No | No | No | No | No | No | No |
Time Keeping Current | 0.5 μA | 0.5 μA | 0.5 μA | 0.5 μA | 0.5 μA | 0.5 μA | 0.5 μA |
VCC (max) | 3.6 V | 3.6 V | 3.6 V | 3.6 V | 3.6 V | 3.6 V | 3.6 V |
VCC (min) | 1.4 V | 1.4 V | 1.4 V | 1.4 V | 1.4 V | 1.4 V | 1.4 V |
Интерфейс | I2C | I2C | I2C | I2C | I2C | I2C | I2C |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL12058 (7)
- Timing & Digital ICs > Real Time Clocks > Real Time Clocks
