Datasheet Intersil ISL43140 — Даташит
ПроизводительIntersil
СерияISL43140
Низковольтные, с одинарным и двойным питанием, высокопроизводительные, Quad SPST, аналоговые переключатели
ISL43140, ISL43141, ISL43142 Datasheet
PDF, 1.1 Мб, Версия: 2017-10-26
23 предложений от 21 поставщиков
Low-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog Switches | IC SWITCH QUAD SPST 16SOIC
ISL43140IB
Renesas
60 ₽
ЗУМ-СМД
ISL43140IBZ
Intersil
ISL43140IBZ
Renesas
LifeElectronics
ISL43140IBIBZ
Intersil
ISL43140IBISL43140IB-TISL43140IBZISL43140IBZ-TISL43140IRISL43140IR-TISL43140IRZISL43140IRZ-TISL43140IVISL43140IV-TISL43140IVZISL43140IVZ-T
N123456789101112
Корпус16 Ld SOIC16 Ld SOIC T+R16 Ld SOIC16 Ld SOIC T+R16 Ld QFN16 Ld QFN T+R16 Ld QFN16 Ld QFN T+R16 Ld TSSOP16 Ld TSSOP T+R16 Ld TSSOP16 Ld TSSOP T+R
Parameters / ModelsISL43140IBISL43140IB-TISL43140IBZISL43140IBZ-TISL43140IRISL43140IR-TISL43140IRZISL43140IRZ-TISL43140IVISL43140IV-TISL43140IVZISL43140IVZ-T
Количество каналов444444444444
Chg Inj1 pC1 pC1 pC1 pC1 pC1 pC1 pC1 pC1 pC1 pC1 pC1 pC
ConfigurationNCNCNCNCNCNCNCNCNCNCNCNC
DescriptionLow-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog SwitchesLow-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog SwitchesLow-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog SwitchesLow-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog SwitchesLow-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog SwitchesLow-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog SwitchesLow-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog SwitchesLow-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog SwitchesLow-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog SwitchesLow-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog SwitchesLow-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog SwitchesLow-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog Switches
Drain Cap14 pF14 pF14 pF14 pF14 pF14 pF14 pF14 pF14 pF14 pF14 pF14 pF
IS0.05 μA0.05 μA0.05 μA0.05 μA0.05 μA0.05 μA0.05 μA0.05 μA0.05 μA0.05 μA0.05 μA0.05 μA
Leakage0.01 nA0.01 nA0.01 nA0.01 nA0.01 nA0.01 nA0.01 nA0.01 nA0.01 nA0.01 nA0.01 nA0.01 nA
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp240°C240°C260°C260°C240°C240°C260°C260°C240°C240°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Source Cap7 pF7 pF7 pF7 pF7 pF7 pF7 pF7 pF7 pF7 pF7 pF7 pF
Switch or MUXSwitchSwitchSwitchSwitchSwitchSwitchSwitchSwitchSwitchSwitchSwitchSwitch
TOFF15 ns15 ns15 ns15 ns15 ns15 ns15 ns15 ns15 ns15 ns15 ns15 ns
TON40 ns40 ns40 ns40 ns40 ns40 ns40 ns40 ns40 ns40 ns40 ns40 ns
Type of SwitchSPSTSPSTSPSTSPSTSPSTSPSTSPSTSPSTSPSTSPSTSPSTSPST
VCC (Dual) (max)В±6 VВ±6 VВ±6 VВ±6 VВ±6 VВ±6 VВ±6 VВ±6 VВ±6 VВ±6 VВ±6 VВ±6 V
VCC (Dual) (min)В±2 VВ±2 VВ±2 VВ±2 VВ±2 VВ±2 VВ±2 VВ±2 VВ±2 VВ±2 VВ±2 VВ±2 V
VCC (Single) (max)12 V12 V12 V12 V12 V12 V12 V12 V12 V12 V12 V12 V
VCC (Single) (min)2 V2 V2 V2 V2 V2 V2 V2 V2 V2 V2 V2 V
rDS(ON)50 Ω50 Ω50 О©50 О©50 Ω50 Ω50 О©50 О©50 Ω50 Ω50 О©50 О©
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
ISL43141
  • Switches, MUX & Crosspoints > Medium Voltage > Switches/MUXs/Crosspoints
На английском языке: Datasheet Intersil ISL43140
