Datasheet Intersil ISL43141 — Даташит
Производитель | Intersil |
Серия | ISL43141 |
Низковольтные, с одинарным и двойным питанием, высокопроизводительные, Quad SPST, аналоговые переключатели
![]() 33 предложений от 23 поставщиков Low-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog Switches | IC SWITCH QUAD SPST 16SOIC | |||
ISL43141IVZ Renesas | от 34 ₽ | ||
ISL43141IBZ Renesas | 230 ₽ | ||
ISL43141IB Intersil | по запросу | ||
ISL43141IVZ-T Intersil | по запросу |
ISL43141IB | ISL43141IB-T | ISL43141IBZ | ISL43141IBZ-T | ISL43141IR | ISL43141IR-T | ISL43141IRZ | ISL43141IRZ-T | ISL43141IV | ISL43141IV-T | ISL43141IVZ | ISL43141IVZ-T | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
Корпус | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld QFN | 16 Ld QFN T+R | 16 Ld QFN | 16 Ld QFN T+R | 16 Ld TSSOP | 16 Ld TSSOP T+R | 16 Ld TSSOP | 16 Ld TSSOP T+R |
Parameters / Models | ISL43141IB | ISL43141IB-T | ISL43141IBZ | ISL43141IBZ-T | ISL43141IR | ISL43141IR-T | ISL43141IRZ | ISL43141IRZ-T | ISL43141IV | ISL43141IV-T | ISL43141IVZ | ISL43141IVZ-T |
Количество каналов | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Chg Inj | 1 pC | 1 pC | 1 pC | 1 pC | 1 pC | 1 pC | 1 pC | 1 pC | 1 pC | 1 pC | 1 pC | 1 pC |
Configuration | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO | NO |
Description | Low-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog Switches | Low-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog Switches | Low-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog Switches | Low-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog Switches | Low-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog Switches | Low-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog Switches | Low-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog Switches | Low-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog Switches | Low-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog Switches | Low-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog Switches | Low-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog Switches | Low-Voltage, Single and Dual Supply, High Performance, Quad SPST, Analog Switches |
Drain Cap | 14 pF | 14 pF | 14 pF | 14 pF | 14 pF | 14 pF | 14 pF | 14 pF | 14 pF | 14 pF | 14 pF | 14 pF |
IS | 0.05 μA | 0.05 μA | 0.05 μA | 0.05 μA | 0.05 μA | 0.05 μA | 0.05 μA | 0.05 μA | 0.05 μA | 0.05 μA | 0.05 μA | 0.05 μA |
Leakage | 0.01 nA | 0.01 nA | 0.01 nA | 0.01 nA | 0.01 nA | 0.01 nA | 0.01 nA | 0.01 nA | 0.01 nA | 0.01 nA | 0.01 nA | 0.01 nA |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Source Cap | 7 pF | 7 pF | 7 pF | 7 pF | 7 pF | 7 pF | 7 pF | 7 pF | 7 pF | 7 pF | 7 pF | 7 pF |
Switch or MUX | Switch | Switch | Switch | Switch | Switch | Switch | Switch | Switch | Switch | Switch | Switch | Switch |
TOFF | 15 ns | 15 ns | 15 ns | 15 ns | 15 ns | 15 ns | 15 ns | 15 ns | 15 ns | 15 ns | 15 ns | 15 ns |
TON | 40 ns | 40 ns | 40 ns | 40 ns | 40 ns | 40 ns | 40 ns | 40 ns | 40 ns | 40 ns | 40 ns | 40 ns |
Type of Switch | SPST | SPST | SPST | SPST | SPST | SPST | SPST | SPST | SPST | SPST | SPST | SPST |
VCC (Dual) (max) | В±6 V | В±6 V | В±6 V | В±6 V | В±6 V | В±6 V | В±6 V | В±6 V | В±6 V | В±6 V | В±6 V | В±6 V |
VCC (Dual) (min) | В±2 V | В±2 V | В±2 V | В±2 V | В±2 V | В±2 V | В±2 V | В±2 V | В±2 V | В±2 V | В±2 V | В±2 V |
VCC (Single) (max) | 12 V | 12 V | 12 V | 12 V | 12 V | 12 V | 12 V | 12 V | 12 V | 12 V | 12 V | 12 V |
VCC (Single) (min) | 2 V | 2 V | 2 V | 2 V | 2 V | 2 V | 2 V | 2 V | 2 V | 2 V | 2 V | 2 V |
rDS(ON) | 50 Ω | 50 Ω | 50 О© | 50 О© | 50 Ω | 50 Ω | 50 О© | 50 О© | 50 Ω | 50 Ω | 50 О© | 50 О© |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL43141 (12)
- Switches, MUX & Crosspoints > Medium Voltage > Switches/MUXs/Crosspoints
