Клеммные колодки Keen Side
Datasheet Intersil ISL32430E — Даташит
ПроизводительIntersil
СерияISL32430E
В±40V Fault Protected, 3.3V to 5V, В±15V CMR, 250kbps Full-duplex RS-485/RS-422, В±15kV ESD
ISL32430E, ISL32432E, ISL32433E, ISL32435E, ISL32437E Datasheet
PDF, 1.2 Мб, Версия: 2017-10-10
Чип интерфейса, 40V OVP, 15V CMR, -40+85, 3V RS-485 FULL DUPL 250KBPS TRANS, HT SUSA CODE:8542390000
ISL32430EIUZ
Renesas
80 ₽
ISL32430EIBZ-T
Intersil
147 ₽
ISL32430EIUZ-T
Intersil
186 ₽
ISL32430EIBZ
Renesas
ISL32430EIBZISL32430EIBZ-TISL32430EIBZ-T7AISL32430EIUZISL32430EIUZ-TISL32430EIUZ-T7A
N123456
Корпус14 Ld SOIC14 Ld SOIC T+R14 Ld SOIC T+R10 Ld MSOP10 Ld MSOP T+R10 Ld MSOP T+R
Parameters / ModelsISL32430EIBZISL32430EIBZ-TISL32430EIBZ-T7AISL32430EIUZISL32430EIUZ-TISL32430EIUZ-T7A
# of Rx111111
# of Tx111111
Common Mode Voltage RangeВ±15 VВ±15 VВ±15 VВ±15 VВ±15 VВ±15 V
Скорость передачи данных.25 Mbps.25 Mbps.25 Mbps.25 Mbps.25 Mbps.25 Mbps
Description?40V Fault Protected, 3.3V to 5V, ?15V CMR, 250kbps Full-duplex RS-485/RS-422, ?15kV ESD?40V Fault Protected, 3.3V to 5V, ?15V CMR, 250kbps Full-duplex RS-485/RS-422, ?15kV ESD?40V Fault Protected, 3.3V to 5V, ?15V CMR, 250kbps Full-duplex RS-485/RS-422, ?15kV ESD?40V Fault Protected, 3.3V to 5V, ?15V CMR, 250kbps Full-duplex RS-485/RS-422, ?15kV ESD?40V Fault Protected, 3.3V to 5V, ?15V CMR, 250kbps Full-duplex RS-485/RS-422, ?15kV ESD?40V Fault Protected, 3.3V to 5V, ?15V CMR, 250kbps Full-duplex RS-485/RS-422, ?15kV ESD
Devices Allowed on Bus128128128128128128
Fault Voltage LevelВ±40 VВ±40 VВ±40 VВ±40 VВ±40 VВ±40 V
Half/Full DuplexFullFullFullFullFullFull
High ESD?YesYesYesYesYesYes
Hot PlugNoNoNoNoNoNo
ICC2.1 mA2.1 mA2.1 mA2.1 mA2.1 mA2.1 mA
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp260°C260°C260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandard
SHDN ICC10 μA10 μA10 μA10 μA10 μA10 μA
Slew Rate LimitedYesYesYesYesYesYes
Tx/Rx EnableYesYesYesYesYesYes
VCC (min)3 V3 V3 V3 V3 V3 V
VL PinNoNoNoNoNoNo
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
ISL32432E ISL32433E ISL32435E ISL32437E
  • Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
На английском языке: Datasheet Intersil ISL32430E
