Datasheet Intersil ISL32459EIBZ-T7A — Даташит
Производитель | Intersil |
Серия | ISL32459E |
Модель | ISL32459EIBZ-T7A |
В±60V Fault Protected, 3.3V to 5V, В±20V CMR, 20Mbps RS-485 With Cable Invert, В±15kV ESD
ISL32450E, ISL32452E, ISL32453E, ISL32455E, ISL32457E, ISL32458E, ISL32459E Datasheet
PDF, 1.6 Мб, Версия: 2017-08-31
![]() 18 предложений от 9 поставщиков Чип интерфейса, ±60V Fault Protected, 3.3V to 5V, ±20V CMR, 20Mbps RS-485 With Cable Invert, ±15kV ESD | |||
ISL32459EIBZ-T7A Intersil | 260 ₽ | ||
ISL32459EIBZ-T7A Intersil | 262 ₽ | ||
ISL32459EIBZ-T7A Intersil | 280 ₽ | ||
ISL32459EIBZ-T7A Renesas | по запросу |
Корпус | 8 Ld SOIC T+R |
# of Rx | 1 |
# of Tx | 1 |
Common Mode Voltage Range | В±20 V |
Скорость передачи данных | 20 Mbps |
Description | ?60V Fault Protected, 3.3V to 5V, ?20V CMR, 20Mbps RS-485 With Cable Invert, ?15kV ESD |
Devices Allowed on Bus | 128 |
Fault Voltage Level | В±60 V |
Half/Full Duplex | Half |
High ESD? | Yes |
Hot Plug | No |
ICC | 2.1 mA |
Peak Temp | 260°C |
SHDN ICC | 10 μA |
Slew Rate Limited | No |
Tx/Rx Enable | Tx Only |
VCC (min) | 3.0 V |
VL Pin | No |
ISL32450E ISL32452E ISL32453E ISL32455E ISL32457E ISL32458E
Серия: ISL32459E (3)
- ISL32459EIBZ ISL32459EIBZ-T ISL32459EIBZ-T7A
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
ISL32459EIBZT7A, ISL32459EIBZ T7A
