Клеммные колодки Keen Side
Datasheet Intersil X9C104 — Даташит
ПроизводительIntersil
СерияX9C104
Потенциометр с цифровым управлением (XDCP)
X9C102, X9C103, X9C104, X9C503 Datasheet
PDF, 529 Кб, Версия: 31-10-2017
56 предложений от 27 поставщиков
Энергонезависимый цифровой потенциометр, 100 кОм, Одиночный, Последовательный, Линейный, ± 20%
X9C104ST1
Intersil
11 ₽
X9C104PI
29 ₽
X9C104S
Intersil
68 ₽
МосЧип
X9C104D
Intersil
X9C104PX9C104P-3X9C104PIX9C104PIZX9C104PMX9C104SX9C104SIX9C104SI-ZX9C104SIT1X9C104SIT2X9C104SIZX9C104SIZT1X9C104SIZT2X9C104ST1X9C104ST2X9C104ST4X9C104SZX9C104SZT1X9C104SZT2
N12345678910111213141516171819
Корпус8 Ld PDIP8 Ld PDIP8 Ld PDIP8 Ld PDIPRetired - Please contact us for package data8 Ld8 Ld SOIC8 Ld SOIC8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC T+RRetired - Please contact us for package data8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R
Parameters / ModelsX9C104PX9C104P-3X9C104PIX9C104PIZX9C104PMX9C104SX9C104SIX9C104SI-ZX9C104SIT1X9C104SIT2X9C104SIZX9C104SIZT1X9C104SIZT2X9C104ST1X9C104ST2X9C104ST4X9C104SZX9C104SZT1X9C104SZT2
# of Taps100100100100100100100100100100100100100100100100100100100
Количество каналов1111111111111111111
DescriptionDigitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)
Dual Supply Range (V)N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
End-to-End Tempco (В±ppm/В°C)300300300300300300300300300300300300300300300300300300300
Основные особенностиIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5V
ICC750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA
Interface Type3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)
Max Operating Temp85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C
Memory TypeNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatile
Middlepoint Ratiometric Tempco20202020202020202020202020202020202020
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp240°C240°C240°C240°C240°C260°C260°C260°C240°C240°C240°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Resistance Options (kΩ)100100100100100100100100100100100100100100100100100100100
Resistance Options (kО©)100100100100100100100100100100100100100100100100100100100
Resistance TaperLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinear
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V
VL Max. Terminal Voltage5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V
VL Min. Terminal Voltage-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V
Wiper Current4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA
Wiper Resistance40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©
Интерфейс3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместим
X9C102 X9C103 X9C503
  • Data Converters > Digital Potentiometers (DCPs) > DCPs
На английском языке: Datasheet Intersil X9C104
