Datasheet LMH6321MR - National Semiconductor Даташит BUFFER, CURRENT HIGH SPD/O/P, SOP8 — Даташит
National Semiconductor LMH6321MR
Наименование модели: LMH6321MR
40 предложений от 18 поставщиков
LMH6321MR
85 ₽
LMH6321MR/NOPB
от 92 ₽
LMH6321MR/NOPB
191 ₽
LMH6321MR/NOPB
от 1 115 ₽
Описание: BUFFER, CURRENT HIGH SPD/O/P, SOP8
data sheetСкачать Data Sheet
LMH6321 300 mA High Speed Buffer with Adjustable Current Limit
April 2007
General Description
The LMH6321 is a high speed unity gain buffer that slews at 1800 V/µs and has a small signal bandwidth of 110 MHz while driving a 50 load.
It can drive ±300 mA continuously and will not oscillate while driving large capacitive loads. The LMH6321 features an adjustable current limit. The current limit is continuously adjustable from 10 mA to 300 ma with a ±5 mA ±5% accuracy. The current limit is set by adjusting an external reference current with a resistor. The current can be easily and instantly adjusted, as needed by connecting the resistor to a DAC to form the reference current. The sourcing and sinking currents share the same current limit. The LMH6321 is available in a space saving 8-pin PSOP or a 7-pin TO-263 power package. The PSOP package features an exposed pad on the bottom of the package to increase its heat sinking ca
Данные для моделированияДанные для моделирования
  • Number of Amplifiers: 1
  • Gain Bandwidth: 110 МГц
  • Slew Rate: 2900 В/мкс
  • Диапазон напряжения питания: 5 В ... ± 16 В
  • Выходной ток: 300 мА
  • Amplifier Output: Single Ended
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOP
  • Amplifier Type: Buffer
  • Семейство: 6321
  • Рабочий диапазон температрур: -40°C ... +125°C
  • Output Current Max: 300 мА
  • Output Type: Single Ended
  • Способ монтажа: SMD
На английском языке: Datasheet LMH6321MR - National Semiconductor BUFFER, CURRENT HIGH SPD/O/P, SOP8
