Datasheet Intersil HI5731 — Даташит
Производитель | Intersil |
Серия | HI5731 |
12-разрядный высокоскоростной цифро-аналоговый преобразователь, 100 MSPS
Купить HI5731 на РадиоЛоцман.Цены — от 63 до 7 745 ₽ 22 предложений от 21 поставщиков Цифро-аналоговые преобразователи (ЦАП) 28 INDTEMP D/A 12 BIT 100MHZ -5 2V | |||
HI5731BIPZ Rochester Electronics | от 63 ₽ | ||
HI5731BIBZ-T Intersil | 80 ₽ | ||
HI5731BIB Intersil | по запросу | ||
HI5731_04 Intersil | по запросу |
HI5731BIB | HI5731BIB-T | HI5731BIBZ | HI5731BIP | HI5731BIPZ | |
N | 1 | 2 | 3 | 4 | 5 |
Корпус | 28 Ld SOIC | 28 Ld SOIC T+R | 28 Ld SOIC | 28 Ld PDIP | 28 Ld PDIP |
Parameters / Models | HI5731BIB | HI5731BIB-T | HI5731BIBZ | HI5731BIP | HI5731BIPZ |
± DNL (Diff. Non-Linearity) (LSB) | 1 | 1 | 1 | 1 | 1 |
± INL (Integral Non-Linearity) (LSB) | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 |
Description | 12-Bit, 100 MSPS, High Speed D/A Converter | 12-Bit, 100 MSPS, High Speed D/A Converter | 12-Bit, 100 MSPS, High Speed D/A Converter | 12-Bit, 100 MSPS, High Speed D/A Converter | 12-Bit, 100 MSPS, High Speed D/A Converter |
Max Conv Rate (MSPS) | 100 | 100 | 100 | 100 | 100 |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Output I/V | I | I | I | I | I |
Peak Temp | 240°C | 240°C | 260°C | ||
Power (mW) | 650mW at 100Msps | 650mW at 100Msps | 650mW at 100Msps | 650mW at 100Msps | 650mW at 100Msps |
Qualification Level | Standard | Standard | Standard | Standard | Standard |
Разрешение | 12 | 12 | 12 | 12 | 12 |
SFDR (typ) to Nyquist (dBc) | 69dBc 2MHz@100Msps | 69dBc 2MHz@100Msps | 69dBc 2MHz@100Msps | 69dBc 2MHz@100Msps | 69dBc 2MHz@100Msps |
VREF | Int/Ext | Int/Ext | Int/Ext | Int/Ext | Int/Ext |
В± DNL (Diff. Non-Linearity) (LSB) | 1 | 1 | 1 | 1 | 1 |
В± INL (Integral Non-Linearity) (LSB) | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 |
Серия: HI5731 (5)
- Data Converters > D/A Converters > D/A Converters
