Datasheet Intersil ISL78171 — Даташит
Производитель | Intersil |
Серия | ISL78171 |
6-канальный автомобильный светодиодный драйвер с током 50 мА со сверхвысоким коэффициентом затемнения и управлением фазовым сдвигом
![]() 7 предложений от 7 поставщиков Драйвер LED , LED Driver 72Segment 5V/9V/12V/15V/18V Automotive 20Pin QFN EP Tube | |||
ISL78171ARZ Renesas | 70 ₽ | ||
ISL78171ARZ Intersil | 121 ₽ | ||
ISL78171ARZ-T Renesas | по запросу |
ISL78171ARZ | ISL78171ARZ-T | ISL78171ARZ-T7A | |
N | 1 | 2 | 3 |
Корпус | 20 Ld QFN | 20 Ld QFN T+R | 20 Ld QFN T+R |
Parameters / Models | ISL78171ARZ | ISL78171ARZ-T | ISL78171ARZ-T7A |
# of LEDs (max) | 72 | 72 | 72 |
Backlight for LCD Size (max) | 17 in | 17 in | 17 in |
Backlight for LCD Size (min) | 0 in | 0 in | 0 in |
Brightness Control | SMBus, PWM or DC | SMBus, PWM or DC | SMBus, PWM or DC |
Количество каналов | 6 | 6 | 6 |
Description | 6-Channel, 50mA Automotive LED Driver with Ultra-high Dimming Ratio and Phase Shift Control | 6-Channel, 50mA Automotive LED Driver with Ultra-high Dimming Ratio and Phase Shift Control | 6-Channel, 50mA Automotive LED Driver with Ultra-high Dimming Ratio and Phase Shift Control |
Fault Switch | Yes | Yes | Yes |
Тактовая частота | 0.6/1.2 MHz | 0.6/1.2 MHz | 0.6/1.2 MHz |
IQ (max) | 5 μA | 5 μA | 5 μA |
ISW (typ) | 2000 mA | 2000 mA | 2000 mA |
Integrated Diode | No | No | No |
Interface Type | SMBus/I2C | SMBus/I2C | SMBus/I2C |
Рабочий диапазон температур | от -40 до 105 | от -40 до 105 | от -40 до 105 |
Output Current Max/Channel | 50 mA | 50 mA | 50 mA |
Over Voltage Protection | Yes | Yes | Yes |
Peak Efficiency (%) | 92.9 | 92.9 | 92.9 |
Peak Temp | 260°C | 260°C | 260°C |
Qualification Level | Automotive | Automotive | Automotive |
Topologies | Inductor Boost | Inductor Boost | Inductor Boost |
Total Current for DC/DC Lighting | 300 mA | 300 mA | 300 mA |
VIN (max) (V) | 26.5 | 26.5 | 26.5 |
VIN (min) (V) | 4.5 | 4.5 | 4.5 |
VOUT (max) (V) | 40 | 40 | 40 |
Интерфейс | SMBus/I2C | SMBus/I2C | SMBus/I2C |
Серия: ISL78171 (3)
- End Market Specific > Automotive ICs > LED Backlight Drivers
