Datasheet Intersil ISL54065 — Даташит
Производитель | Intersil |
Серия | ISL54065 |
Отрицательное колебание сигнала, субомное сопротивление, двойной SPDT с устранением щелчков и щелчков, одиночный переключатель питания с контактом включения
![]() 17 предложений от 11 поставщиков +1.8V to +6.5V, Sub-ohm, Click and Pop Elimination, Dual SPDT w/ Enable, Analog Switch with Negative Signal Capability | |||
ISL54065IRUZ-T Intersil | 53 ₽ | ||
ISL54065IRUZ-T Renesas | 204 ₽ | ||
ISL54065 Intersil | по запросу | ||
ISL54065IRUZ-T Renesas | по запросу |
ISL54065IRUZ-T | |
N | 1 |
Корпус | 12 Ld uTQFN T+R |
Parameters / Models | ISL54065IRUZ-T |
Configuration | Dual NO |
Description | Negative Signal Swing, Sub-ohm, Dual SPDT with Click and Pop Elimination Single Supply Switch with Enable Pin |
Insertion Loss @ 20kΩ Load | N/A dB |
Insertion Loss @ 20kО© Load | N/A dB |
Off-Isolation @ 20kHz, 20kΩ Load | N/A dB |
Off-Isolation @ 20kHz, 20kО© Load | N/A dB |
Peak Temp | 260°C |
Switch or MUX | Stereo Switch |
THD+N 20kΩ Load @ 2VRMS (%) | N/A |
THD+N 20kО© Load @ 2VRMS (%) | N/A |
THD+N 32Ω Load @ 3.9mW (%) | 0.02 |
THD+N 32О© Load @ 3.9mW (%) | 0.02 |
Type of Switch | SPDT |
VS (max) | 6.5 V |
VS (min) | 1.8 V |
rDS(ON) | 0.52 Ω |
ISL54065IRUZ-T | |
Серия: ISL54065 (1)
- Audio & Video > Audio Switches > Audio Click and Pop
